Old 10-05-2016, 02:30 PM
Jfive Jfive is offline
Default Hemi no start.
Installed a 22mm motorcycle carb, and can't get it to fire. Has custom intake. Header and governor removed. Never fired new with oem carb. Cam came out with cover but reinstalled with the piston at TDC and dots lined up. Now does it have waste spark or could that affect TDC if off a revolution.
Old 10-05-2016, 03:04 PM
Poboy kartman Poboy kartman is offline
Banned
Your pushrods are probably not under the rocker arms.
If you're not getting spark it may not have enough oil.
The Following User Says Thank You to Poboy kartman For This Useful Post:
bob58o (10-05-2016)
Old 10-05-2016, 03:14 PM
BirdFanatic BirdFanatic is offline
Is the pull cord trying to eat your arm ?
@@Caution burns rubber often
Old 10-05-2016, 04:17 PM
Removed oil sensor filled with 16oz. Oil, but might be lifter. I had one that kept falling out. Had spark but didn't seam to get fuel. I'll get starter fluid at Wal-Mart tonight pull valve cover check that and retry.
---------- Post added at 05:17 PM ---------- Previous post was at 05:16 PM ----------
My arms tired from pulling it but just cause it would not start.
Old 10-05-2016, 04:39 PM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Take off the valve cover, fix the pushrods, set the lash
---------- Post added at 05:39 PM ---------- Previous post was at 05:37 PM ----------
Or make it look stock and return it to Harbor Freight.
That is what I did, cause I didn't know to fix the pushrods.
There are two types of people. Those who can extrapolate from incomplete data
Old 10-05-2016, 04:52 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Try not to Suck Bob!
Why don't you, go back to your double wide and fry something!
The Following User Says Thank You to chancer For This Useful Post:
Whitetrashrocker (10-05-2016)
Old 10-06-2016, 11:08 AM
Took the valve cover off, and both push rods were off the rocker arms. I'll assume that was it. Need to look up lash and I'll check it. Then later today I'll put it outside and retry to fire it up.
Old 10-06-2016, 11:21 AM
Banned
That'll do it!!! You can double check...and someone correct me if I'm wrong...but on the newer Predators I believe they are 0.003" for both intake and exhaust.
bob58o (10-06-2016)
Old 10-06-2016, 11:38 AM
aham2003 aham2003 is offline
That is what I set my last hemi build at and it ran great.
The Following User Says Thank You to aham2003 For This Useful Post:
Poboy kartman (10-06-2016)
Old 10-06-2016, 11:45 AM
Banned
JIK....The lash needs to be set at TDC on the COMPRESSION stroke....TDC on the exhuast and it won't run.
  #11
Old 10-06-2016, 02:49 PM
Probably has too much lash. I didn't check it yet but could see it with my eyes. Runs now and just need to have it mounted to get a video. Hit the throttle and I straight rips compared to oem carb on my lifan. Idle is low so I'll need to adjust it, but fired first pull. How I have it rigged to start.
  #12
Old 10-06-2016, 03:03 PM
Bbqjoe Bbqjoe is offline
Banned
So, you're starting it with an angle grinder?
  #13
Old 10-06-2016, 03:06 PM
Yes Pat pending.
Also runs on water from culigan.
The Following User Says Thank You to Jfive For This Useful Post:
chancer (10-06-2016)
  #14
Old 10-06-2016, 06:59 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Fooling around with the engine after the truth of the above statement was realized was your first mistake.
You did not purchase a functioning, viable product and the whole cash for goods transaction was null and void. You should have exchanged it at the store.
  #15
Old 10-06-2016, 07:53 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Did you read the thread? He messed up the lifters removing the Govna'
and he has already fixed his mistake.
But, hey thanks for posting, always good to hear from you
