Old 03-25-2019, 10:05 PM
BirdFanatic BirdFanatic is offline
Default Vanguard performance
What are the steps I need to take in order to get a lot more ponies out of a vanguard 16hp v twin in the back of my mini cup ? I wanna take it beyond where it is do I need to upgrade rods ? Flywheel?
@@Caution burns rubber often
The Following User Says Thank You to BirdFanatic For This Useful Post:
HONEYBADGERFTW (03-29-2019)
Old 03-25-2019, 10:14 PM
Tpdingo Tpdingo is offline
A vanguard might be tricky to get a hold of parts for...but if you can this is what you should do.
Things to do, in the order they should be done.
Exhaust system: straight pipe it.
Governor delete & New billet rods and flywheel(should go as a combo or risk blowing the motor)
Intake system: new carb/bigger jet, airfilter, etc.
Add a a big lobed cam.
new better spark plug
High compression head...or shave the head/thinner gasket(and usually a change in spark timing)
Port and polish intake and exhaust.
Better valves and rockers.
Past this, I think you just need to get a bigger/better motor.
Old 03-26-2019, 07:52 AM
I REALLY can't understand why you need MORE than 16 HP.
Unless you're doing something like the Carsandcameras Predator 670 rail dragster.
You could also just GET a Predator 670, then you can for sure get parts from: https://www.performance670.com/index.php
Currently Flathead-Crazed
Old 03-29-2019, 02:32 AM
HONEYBADGERFTW HONEYBADGERFTW is offline
I’m curious as well, subscribed to this thread. I have a vanguard (was told 18 hp, but I haven’t fact checked that yet), and I’m going to put it on a Manco Silver Fox that I recently acquired. And in my case at least, I want to make a high hp kart because why not? Lol. Yeah, I could fork out cash and buy a Vegas carts engine, predator v twin, etc but I want to be able to sit back, crack open a cold one and have that sense of accomplishment that I put it together. I’m not a racer or even close but I like going faster than my buddies. Oh, my friend named the kart I’m building Death Machine because of obvious reasons lmao.
Old 03-29-2019, 05:49 AM
Kartorbust's Avatar
There's quite a bit you can buy. Better 2 barrel carburetors, billet flywheel with starter ring gear, billet connecting rods. Most who build these Vanguards are either mower racers and mud motor boaters. I would look at Back Water and ARC Racing. Just search Briggs Vanguard 16hp or model 30 and you should find a lot of performance parts for it. But these will be expensive so you'll have to stretch it out over time. Even modding a Predator 670 would be just as expensive.
Sent from my SM-A600A using Tapatalk
65ShelbyClone (03-29-2019)
Old 03-29-2019, 08:52 AM
Originally Posted by Kartorbust View Post
...Even modding a Predator 670 would be just as expensive.
And as a bonus, you get to pay ~$700 for a brand new one.
Old 03-29-2019, 09:56 AM
65ShelbyClone's Avatar
65ShelbyClone 65ShelbyClone is offline
Step one is gather up about $1000 to get started with. The rods and flywheel will burn off $600 right out of the gate. A cam will be 200-300 and pistons 150-200. There goes your grand without even getting into the heads, exhaust, induction, and machine work for which I would budget another $1000.
Old 03-29-2019, 10:10 AM
JEEZ! You could buy a project car for that much!
Old 03-29-2019, 11:32 AM
Kartorbust's Avatar
Flywheel with ring gear https://www.arcracing.com/6611-vg-ar...heel-vanguard/
Billet connecting rod https://www.arcracing.com/6275-arc-b...anguard-4-134/
Small block vanguard cam:
https://www.precisioncams.com/mower.html
As a side note, the Vanguard 16hp shares the same parts with the 14hp as well. Really it's just the carburetor that makes the difference between the two.
With just these mods, you are looking easily around $750. That's not including ratio roller rockers, head work, different valves, different push rods (all extra stuff that could help).
You can still have a ton of fun with a mild build, billet rods, valve springs (highly suggest getting the tool to compress them, 60lbs is not an easy task), flywheel. A bit of polishing on the exhaust port will help it breathe better.
Old 03-29-2019, 06:15 PM
Funny you say that because the average purchase price between my project cars is $2050. That's just a fraction of what's in them though.
The Following User Says Thank You to 65ShelbyClone For This Useful Post:
MTopp (12-04-2019)
  #11
Old 03-29-2019, 06:20 PM
Well, yeah. My dad used to have an old project Toyota Corolla(trying to save money), that he bought for 2K. We ended up ditching it(giving up, not driving it into a ditch).
It was not a very good deal, but yeah, for the cost of doing serious upgrades on any twin cylinder, you can buy a car.
MTopp (12-04-2019)
  #12
Old 03-29-2019, 08:16 PM
anickode's Avatar
anickode anickode is online now
It was not a very good deal, but yeah, for the cost of doing serious upgrades on any twin cylinder, you can but a car.
Yes, for what a full build costs on a v twin, you can probably buy a used 600cc sport bike engine from a junkyard and a lot of the necessary parts to install it.
"Well that would be a bomb."
  #13
Old 11-09-2019, 02:18 PM
Forgot to tell everyone I found out it wasn't a mini cup it was a mini sportsman .it was not a 16hp vanguard it was a 20hp vanguard with a rev kit Nikki carb
  #14
Old 11-09-2019, 02:29 PM
Huh?
Say WHAT??
What are you even talking about?!
  #15
Old 11-09-2019, 02:37 PM
Made a post back in March April about a mini cup and it have a 16hp motor and wanting to make it have more ponies . It was not a mini cup and it was not 16hp
---------- Post added at 03:37 PM ---------- Previous post was at 03:34 PM ----------
It was very similar but a southern copy of one so to speak called a mini sportsman truck . They weigh 675 pounds powered by modified 20hp vanguard's .
  #16
Old 11-09-2019, 02:38 PM
Can we see some pics? I don't really know what you're talking about.
And I went back and read your old thread. Maybe a moderator could merge these threads?
  #17
Old 11-09-2019, 02:52 PM
Locked out of the other one -.-
  #18
Old 11-09-2019, 03:09 PM
Mods can fix that.
  #19
Old 11-10-2019, 03:27 AM
Just thought I'd correct my self for that last one went back to try and it was not there .
  #20
Old 11-10-2019, 07:21 AM
itsid's Avatar
itsid itsid is online now
merged & reopened old thread
JTSpeedDemon (11-10-2019)
