Closed Thread
Old 10-14-2013, 08:53 AM
kris62 kris62 is offline
Junior Member
Default bought kart number 2 could use some help
hello bought a second kart this one is a streaker has 11 horse briggs took her for a spin yesterday wow need to figure away to make this ride smoother backs to old for it anyway i can smooth ride out im gonna drop tire pressure down to 3.5 psi see if that helps also any way to add suspension to these hard tails gotta figure something out any help would be great.
Old 10-14-2013, 09:22 AM
OzFab's Avatar
OzFab OzFab is offline
Quote:
That's a good start...
Some pics of the rear end would help with that
Old 10-14-2013, 12:05 PM
rocketkart's Avatar
rocketkart rocketkart is offline
weld some old car springs to the rim to the hubs lol like a slinky jk dont do that.
Old 10-14-2013, 02:30 PM
KartFab's Avatar
KartFab KartFab is offline
Replace the padding on the seat with high density foam. Standard thickness is usually around 2", but you could probably double that. Found at any artsy craft store type place. Make sure it's high density foam
Old 10-14-2013, 05:27 PM
OzFab's Avatar
Quote:
Originally Posted by rocketkart View Post
weld some old car springs to the rim to the axles and spindles lol like a slinky jk dont do that.
No, never, ever, ever, ever, ever, ever, ever, ever weld anything to an axle
Old 10-14-2013, 06:04 PM
Junior Member
Thanks will get some rear end pics tomorrow was thinking also about some bigger front tires like that are more ballon type and run about 3 psi seat padding good idea gonna look into that to anyone ever make a seat suspension was thinking that may work I also have a old Suzuki four wheeler I could use for suspension parts just don't know where or how to start or if it can even be done
  #7
Old 10-14-2013, 06:32 PM
OzFab's Avatar
I have, on my daughters kart (look at the pics in the first two posts); stole the idea (&, in fact, the hardware) from a riding mower
  #8
Old 10-15-2013, 06:17 PM
Junior Member
heres some pics of the rearend im wanting to put a suspension on any help would be fantastic. thanks
  #9
Old 10-15-2013, 07:48 PM
OzFab's Avatar
Need one or two more shots across the kart, just behind the seat...
The first problem I see is the roll cage (if you can call it that) attaches to the rear of the frame. The second problem is that it's not really a roll cage, it's only bolted to the frame, making it more of a brush guard...
Are the uprights behind the seat & the side guards welded or bolted to the frame? They will become the mounting points for the rear shocks...
The Following User Says Thank You to OzFab For This Useful Post:
kris62 (10-15-2013)
  #10
Old 10-15-2013, 08:07 PM
Junior Member
thanks will check in morning almost sure they are bolted on probably not good hey
  #11
Old 10-15-2013, 09:11 PM
OzFab's Avatar
Weeeell, it could be worse
  #12
Old 10-16-2013, 09:10 PM
Junior Member
heres the pics you asked about any hope?
  #13
Old 10-16-2013, 09:15 PM
souperman000's Avatar
souperman000 souperman000 is offline
The tires are designed to be the suspension on this type of kart. Good idea to drop the pressure.
You can add suspension, but it will be a lot of fabrication. But if you're bent on doing it, look at Fab's sig.
It's hard to help people that won't help themselves.
The Following User Says Thank You to souperman000 For This Useful Post:
OzFab (10-17-2013)
  #14
Old 10-17-2013, 09:07 AM
OzFab's Avatar
Ok, rear suspension is possible but, as souperman said, it's gonna take some fab work. Are you up for it?
  #15
Old 10-17-2013, 08:16 PM
Junior Member
i am where would i start
  #16
Old 10-18-2013, 05:25 PM
OzFab's Avatar
You need to start by securely welding the vertical bars behind the seat to the main frame. Then you need to weld the side bars to the frame at the front & to the verticals. This will create a base for suspension mounts.
Oh, FYI, this is a big job which will take a few weeks depending on time availability...
Anyone else think it's worth continuing?
Closed Thread
