Old 05-14-2017, 08:42 PM
zoomy zoomy is offline
Default Jackshaft with torque converter
Tomorrow I am going to buy this go kart, but I need to replace the clutch with a torque converter. The only problem is that it has a jackshaft placed different from where I have normally seen one.
Any idea on how I would install a tav2?
Old 05-14-2017, 09:12 PM
Rail rider's Avatar
Rail rider Rail rider is offline
Inmate # 3192016
Try these. If 1 and 2 don't fix it ...smash it ... I'm so...band now, Lol.
I CAN VOID ITS WARRANTY IN UNDER 5 MINUTES
Old 05-15-2017, 12:41 AM
Bbqjoe Bbqjoe is offline
Banned
I'm confused.
Old 05-15-2017, 03:04 AM
itsid's Avatar
itsid itsid is online now
too bad when one tries to be funny but just appears to be pi55drunk...
Now, back to topic.
Zoomy, unfortunately pics taken in the middle of the night are not going well with my elderly eyes
Anyways, no matter where the jackshaft may be, it's input sprocket is INLINE with the clutch.
thus, as long as you can move the engine a bit closer or further from the jackshaft
(to adjust belt tension) mounting a TC shouldn't be much of an issue.
Old 05-15-2017, 05:14 AM
Forgove me for my stupidity, but would I install the TC so that its output is above the jackshaft input and then run a chain from the TC output to the jackshaft input? I dont think there is enough space to place the tc lvel with the jackshaft
Old 05-15-2017, 06:35 AM
itsid's Avatar
just this once
Ah I see you are talking of having two jackshafts then...
(the one with the TC pulley and the one already on the kart)
I'm not sure that's a good idea, but fair enough...
The sprocket on a TAV Backplate roughly sits at the same lateral distance from the mounting bolts of the engine, as an inbound mounted clutch sprocket would
(in easier terms.. it's roughly 1.5 - 2" further in than your current clutch sprocket)
So in order to use the backplate the engine has to move said distance to the left,
OR the sprocket on the jackshaft has to move said distance to the right.
IMHO, you could just replace the JS sprocket with the driven pulley and run with just one jackshaft
again, the belt needs to run true to both pulleys some minor adjustment will be required.. (i.e. a washer or two on one or the other side, no big deal)
PS Oh, since you likely though about a TAVKit instead of a ordinary TC,
in case you want to just have ONE jackshaft
find a series 30 TC without backplate;
the belt that comes with the backplate is likely not going to be of the correct length,
and you'll need to buy a new one...
so why pay for a belt and a backplate you'll not use in the first place?
Old 05-15-2017, 08:11 AM
Banned
*Snicker*
Old 05-15-2017, 10:37 AM
Oh haha i dont need the jackshaft already on it so i guess i can just move the engine closer to the sprocket and just remove the jackshaft. Sorry!
Old 05-15-2017, 10:51 AM
itsid's Avatar
UHM Nope...
if you remove the jackshaft that's on your kart you should not move the engine,
but the axle sprocket instead!
Old 05-15-2017, 11:00 AM
wouldnt i need to switch to a live axle for the sprocket to be on the inside of the chassis? i dont think the axle goes that far. Isnt that why the sprocket is on the outside of the chassis?
  #11
Old 05-15-2017, 02:53 PM
pRoFiT's Avatar
pRoFiT pRoFiT is offline
Can't buy it?, build it!
Sid is rarely wrong.
I would say a TC driven and driver replace the clutch and sprocket on one side of the jackshaft and you are good to go. maybe like sid said a washer or two to align them. And the right size belt.
But i think you are right on moving engine over if you remove jack shaft completely. and use the TAV2 30 series kit. that comes with a backplate/jackshaft at the correct distance with belt.
if you search google for torque converter and look at images you will see it done both ways. with the adapter plate (that has built in jackshaft) and with an external jackshaft similar to your go kart.
I'm trying to find one that is like yours with a dead axle... mostly done with live axles.
http://www.diygokarts.com/vb/showthread.php?t=25211 this is like yours but he keeps clutch on his go kart.
2016 diygokart Contestant http://www.diygokarts.com/vb/showthread.php?t=33422.
  #12
Old 05-15-2017, 05:52 PM
itsid's Avatar
frankly I cannot see a thing on that midnight pic you've taken
(really.. I mean it's literally just minutes dark outside still noones able to take a pic at daylight...)
Yes I know it's my monitor t
(in fact it's the graphics card not being able to gamma correct anymore)
But still, as if someone called darkness as the new internet picture standard
'Nough rant.
It'll be hard (next to impossible really) to move the engine out far enough to line up the TC sprocket with a wheel sprocket on your kart.
Welding will be necessary as far as I can tell from the second pic you posted
Anyways, either keep the original jackshaft then and scrap the backplate,
or just do not install a TC,
by all means.. a TC with a one wheel peel is a bit tricky to set up;
Torque is pointless without grip, and one wheel only has half the grip of two wheels
Those tyres do not provide good contact anyways
(round profile is nicely cushioned but as you can see from the wear pattern, the contact surface is minimal)
I'm not sure such single wheel would be even capable of providing the traction you need.
  #13
Old 05-17-2017, 06:56 AM
i was thinking about mounting the TC driven on the jackshaft directly, but the problem is that the jackshaft axle is 3/4 and the driven pulley on a tav2 is 5/8.
  #14
Old 05-17-2017, 07:16 AM
mckutzy mckutzy is offline
So what's the problem with how it is without the TC ???
  #15
Old 05-17-2017, 07:42 AM
I'm going to be racing with my friends on a track he made, but its a very curvy track. i'm not going to be using full throttle much, and there is going to be alot of stop and go. not very good for a clutch.
  #16
Old 05-17-2017, 08:20 AM
itsid's Avatar
Not necessarily a proplem, is it?
http://www.mfgsupply.com/gomini/gomi...n/219465a.html
And yes, they make a cheaper chinese clone of that as well ...
So you already have bough a chinese Tav kit, as I'm understanding your persistance in wanting to use it...
too bad
  #17
Old 05-17-2017, 08:57 AM
i didnt buy the tav kit yet, but thanks for the link!
So I have to use an asymmetrical torque convert, right?
  #18
Old 05-17-2017, 05:48 PM
Also, how much length of jackshaft do I need for the driven? I have about 15/16ths of an inch of shaft when i remove the sprocket. I might be able to give myself more space by getting a longer bolt for both sides.
  #19
Old 05-17-2017, 06:23 PM
itsid's Avatar
Thanks for the images.. much better
(well some will moan because of the size... but I don't mind them being big personally)
Ideally you could use the image upload feature of the forum
(attachments.. the paperclip in the editor )
that'd automagically resize all images for everyone's viewing pleasure.
Anyways.
No, you can also use a symmetrical setup, but a series 20 is hard to come by these days (since it's not as good as the series 30) and copies are unlikely to show up (for obvious reasons)
The series 40 is avalable as a chinese copy and just barely more expensive than the series 30 but the driven is one and a half inches bigger in diameter.
It's also not too easy to find a 3/4" driver for a series 40 IIRC.
*shrugs*
But no worries, you can mount the cam facing towards your jackshaftplate w/o any problem if that's what you're wondering about.
here's the driver and driven seperately (same store to save shipping)
MAKE SURE the driver set includes the front spacer (can't tell from the description)
http://www.ebay.com/itm/30-SERIES-DR...dWo6oN&vxp=mtr
http://www.ebay.com/itm/GO-KART-MINI...0AAOSwll1WxJaq
Once you have that mounted you can measure the CTC distance and buy the matching belt.
in fact you can measure it now if you like...
(center PTO to center jackshaft is what you want to know)
(haven't found a complete kit with both for a 3/4" driven I'm afraid.. but just search yourself, maybe you got more luck than me)
  #20
Old 05-17-2017, 07:04 PM
What does the front spacer look like?
Is it this?
If it doesnt have it, can I use a couple washers?
