Go Back   DIY Go Kart Forum > Building Plans And Advice > Using Tools and Welding
Reply
Old 05-16-2019, 08:14 AM
Bmr4Karts Bmr4Karts is offline
Default Using Zinc coated bolts as dowels to repair cut frame?
I'm new to welding and was thinking of using these bolts to fix my cut frame. I'll cut the heads off and use the bolt as a dowel. I'll also cut small slits in each side of the frame tubing and weld the bolt directly to that frame.
Attached are pictures of my frame as it currently sits.
Old 05-16-2019, 10:18 AM
JTSpeedDemon's Avatar
Currently flathead-crazed
DON'T WELD ZINC PLATED STUFF!!
Zinc fumes are highly toxic and can be fatal!
Please go to the hardware store and get some unplated stuff.
King of Controversy
Old 05-16-2019, 12:16 PM
mckutzy mckutzy is offline
Clearly you havent welded enough galv in your life...
Galv isnt deadly to weld... its not good to weld...Hence MFF
Most welders get a bit of fumes already, those bolts are fine, they're not hot dip... that's a bigger thing as there wont be as much fumes...
If you can prep the bolts....take off as much plate as you can by mechanical or chemical means... a sandblaster or even a grinder with a wire wheel...
Having a good ventilated space is about the best place.. so outside is a good idea...
I welded a bunch of stuff galvanized. A good example.... a F-up from a customer missed the couture of the ground when sizing his new gate I built.... Boss comes back and say we need to add extentions to the bottom.... after it got to site and after galv.... All hot dip, and being the bottom of the gate... it was the heaviest deposit of the zinc... they were 20ft long and 1' extentions, both parts galv.... lots of welding... one of the only times I was aloud to take a longer break as I was the only one able to do the job...
It smokes heavily, smells, and tastes bad... drink some milk... and wear a mask with a good amount of ventilation...
But it wont kill you as you strike an arc.... only prolong exposure with out proper ventilation will..
JT- you need to stop and put down the phone/keyboard..... try researching a few things before you spout off knowing about it...
Old 05-16-2019, 12:45 PM
WHOAWHOAWHOA!
Take a lookie at what the DIY Go Karts website says in welding tips:
"Welding Zinc Plated and Galvanized Material
If you didn't already know that welding on zinc is incredibly dangerous, you do now. Breathing the vapors can make you very sick, or end your life. This doesn't mean that you can't weld the material, but it does mean that you need to be very careful."
Yes, I already knew it was possible to weld galvanized/zinc plated material, but it's a very good idea to get some unplated stuff for a beginner welder.
So give me a break.
King of Controversy
Old 05-17-2019, 04:07 AM
itsid's Avatar
itsid itsid is offline
yeah well..
Mac you are clearly right...
But in this case
Quote:
Originally Posted by Bmr4Karts View Post
I'm new to welding .....
I'm with JT here, in just skipping plated stuff.
Stick welders are the better tool for beginners many say for good reason,
but wire welders are more common these days I'd say.
We don't know what welder he got..
but chances are it's a cheap wire welder
(HF 90A kinda deal)
And with that outside welding is unlikely going to happen really well.
And indoor welding safety with galvanized stuff.. I mean yeah...
it's far easier to get unplated bolts, right?
Just to be on the safe side until well enough trained on the arc inducer.
JTSpeedDemon (05-17-2019)
Old 05-21-2019, 03:31 PM
supermanotorious's Avatar
supermanotorious supermanotorious is offline
Winchmaster 5000
When I weld galv I use flux core and keep a fan on the work to expel the fumes as quickly as possible
---------- Post added at 01:31 PM ---------- Previous post was at 01:25 PM ----------
but back on topic, rather than bolts, I'd go to your local steel supply and find some 3/4" OD tube to bridge the 2 halves of the frame
www.phoenixwinch.com
www.facebook.com/wakeskatewinches www.youtube.com/user/phoenixwinch
  #7
Old 05-27-2019, 01:32 AM
I went with solid 3/4" rod. The tubing I had access to was too thin.
  #8
Old 08-15-2019, 01:52 PM
BigWes's Avatar
BigWes BigWes is offline
I hate I missed this when it was going on live. I wouldn't get into the welding debate with different platings just know that as an aircraft mechanic I work around all sorts of different platings and I personally choose not to weld any unless it is an absolute must and then I'll be wearing a breathing apparatus specific to what I'm working with.
On welding certain materials...be aware that bolts are hardened for certain strengths. All bets are off when you heat things up with a welder. Some people don't care what they use for a filler metal. I'd rather use a piece of generic welding steel. I know I'm gonna basically gonna end up with the same thing I started out with. I know bolts. I know they do weird stuff once they get hot. I don't trust them at that point. Anyway, call it a biased opinion if you want. Laugh and carry on if you think I am being stupid. Have fun, be safe.
This ain't rocket science boys!!!
  #9
Old 08-15-2019, 03:36 PM
Dingocat's Avatar
Dingocat Dingocat is online now
Broke
I wonder how it's been going.
Current Manco hoarder
Reply
