Closed Thread
Old 01-13-2018, 11:27 AM
AAIM AAIM is offline
Junior Member
Default Identify this part from a 30 series torque converter
This may sound ridiculous but I cannot find a replacement part online/what it's even called. As you can tell it's a washer type thing that goes on the driver clutch. This is off of an eBay torque converter and I need another one. Someone, please help!
Old 01-13-2018, 12:10 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
Usually called pilot bushings. That one has a slot cut in it.
Think for yourself, Question authority.
The Following 2 Users Say Thank You to Whitetrashrocker For This Useful Post:
AAIM (01-13-2018), bob58o (01-13-2018)
Old 01-13-2018, 01:00 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Kentucky Boy found this on Ebay a while ago.
Torque-Converter-Driver-20-30-Series-Cover-Guard-Insert-3-4-DIA-5-16-Long-Shaft
https://www.ebay.com/itm/110831011812?rmvSB=true
The Following 2 Users Say Thank You to bob58o For This Useful Post:
AAIM (01-13-2018), ezcome-ezgo (01-15-2018)
Old 01-13-2018, 02:23 PM
KingCobra's Avatar
KingCobra KingCobra is offline
TROLL CRUSHER INC.
I always seem to find that people swap them out for regular thick washers and I've never had a problem without them things. I can see that they would keep things straight but when slid together and held with a good washer and bolt, you would wonder how it could go off track anyway as it's held in place with that other gadget that slides over the crank shaft.....
Even though I walk through the darkest valley, I will fear no TROLL...
The Following User Says Thank You to KingCobra For This Useful Post:
AAIM (01-13-2018)
Old 01-13-2018, 02:51 PM
Junior Member
Thanks so much!
---------- Post added at 03:51 PM ---------- Previous post was at 03:48 PM ----------
Quote:
I've used washers before and they work fine for the most part, however, I don't like using washers and I've had problems with the drive pulley being loose when I use washers. Thanks for replying to this thread though!
Closed Thread
