Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
  #21
Old 06-22-2011, 05:36 PM
Doc Sprocket's Avatar
Is this where I point out that both GM and Chrysler went under, and would be just a memory if not for government intervention? Bad manangement does not equal bad product.
  #22
Old 06-22-2011, 05:38 PM
B man's Avatar
B man B man is offline
Tecumseh FTW!
isn't GM now Government Motors?
If it doesn't work......well then its gonna!
  #23
Old 06-22-2011, 05:42 PM
You may have missed my point.
Karl, you've had s**t luck with Tec's. I've had bad luck with major name brands of things. It happens.
  #24
Old 06-22-2011, 05:48 PM
karl's Avatar
karl karl is offline
Well I will stick with briggs and stratton, kohler, and honda. Now for the snowblower. Idk what to do. get another motor? This thing is for re-sale. If I haft to buy another motor there will be a slim profit margin. I dont think you can do much to help the bottom end. May haft to scrap that tecumseh with the other 2 blown up tecumsehs.
  #25
Old 06-22-2011, 05:51 PM
You're right about the profit. Just set it aside and keep your eyes peeled for parts or a cheap engine. When it comes along, flip it for what you can get.
  #26
Old 06-22-2011, 05:54 PM
karl's Avatar
Yea once in awile you can find a cheap engine on craigslist for $20. But the problem it needs to be around the same time period. Then I could transfer all the parts to it like carb and exhaust and It will look factory. I got until winter to finish it, so ill be good. No one wants a snowblower in the middle of summer lol.
  #27
Old 06-22-2011, 05:55 PM
sexyvicta sexyvicta is offline
Originally Posted by karl View Post
Then why is it seized when every briggs ive owned has run perfect until it needs piston rings ? Every tecumseh I have owned was a problematic piece of crap.
lol all the old flat heads are like exactly the same
only minor differences
get a twostroke tecumseh
  #28
Old 06-22-2011, 06:20 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
they didn't sell.
Neither did the Edsel....although they were no different from the Merc's or the the small Fords of the day.
Bad marketing, economic downturn, steel prices...etc. etc.
https://www.youtube.com/watch?v=c4jch0puM1A
  #29
Old 06-22-2011, 06:26 PM
... or the Fiero. I loved mine- knew it inside out. Bad name came from misunderstanding of systems. Where have I heard that before?
  #30
Old 06-22-2011, 06:32 PM
B man's Avatar
Tecumseh FTW!
im not saying they run like crap or won't last.(i found an old 2-stroke tecumseh in my barn one day,but at that point in time i didn't know it was a 2-stroke. wish i had though because it still had loads of compression and it looked clean) but i have a power sport and it runs great just alittle hard starting.
  #31
Old 06-22-2011, 06:47 PM
Russ2251's Avatar
From what I can extract from Karl's posts, he has been dealing with worn out (poorly maintained) engines.
I will admit that Tecumseh engines require a little more tweaking and routine maintenance than what might be considered "normal". However, they do (did) produce much more bang for the buck$.
Keep them tuned with regular maintenance and they will out perform any equivalently sized B&S.
I'm surprised Anderkart has not rung in on this issue.
  #32
Old 06-22-2011, 06:49 PM
B man's Avatar
Tecumseh FTW!
i agree my tecumseh 5.5 kicked my briggs *** when it came to power.
The Following User Says Thank You to B man For This Useful Post:
Russ2251 (06-22-2011)
  #33
Old 06-22-2011, 10:22 PM
redsox985's Avatar
redsox985 redsox985 is offline
I'll have to see how my new 2 stroke 3HP Tec does. It's sitting in a snowblower at the moment awaiting a test soon here. I'm assuming it's a Tec since the carb is marked Tec. I honestly haven't had enough experience to chime in either way here.
  #34
Old 06-22-2011, 10:59 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Originally Posted by B man View Post
tecumseh is out of business i wonder why? hmm maybe they didn't sell? but why wouldn't the sale if they where SOOOO good? beats me.
why did comet torque converter go out of business?
i guess they were just crap too
not trying to start a fight.
The Following 2 Users Say Thank You to Bluethunder3320 For This Useful Post:
dave1701 (06-24-2011), Doc Sprocket (06-25-2011)
  #35
Old 06-22-2011, 11:19 PM
B man's Avatar
Tecumseh FTW!
why did they go out of business? they made a great and useful product.
  #36
Old 06-22-2011, 11:27 PM
probably bad management. im not sure though id have to look it up. but companies that make great products can go out of business.
  #37
Old 06-23-2011, 03:29 AM
bighead's Avatar
bighead bighead is offline
It's like a Ford vrs Chevy vrs Moparts. It's never ending.
The briggs on my tillers and lawn stuff works great. The Powersport engines on the yerf dogs I have had problems with. More so with the carbs. I also have a Tec on a snow blower that has ran great for over ten years.
I like them both though. But like Russ said I was dealing with Yerfdogs that were run into the ground with zero up keeping. Not even minor stuff. I pulled the bowl and I can see the last owner used vise grips to work on the carb.
All that being said, A snow blower should have low hours really. Same with tillers for the most part. Mine does for I only use two times a year.
Attention Criminals!! This is a defense free crime zone. All law-abiding citizens have been disarmed for your convenience.
  #38
Old 06-24-2011, 11:13 AM
karl's Avatar
It snows alot where I live in winter, so snowblowers get used alot. Funny you say tillers, I just bought one for $20. Needs some cleaning up and carb clean, and I can sell it for $50+.
Well I got the snowblower running and the bottom end freed up. Im gonna sell it at the start of winter. My plan is gonna be to keep buying crap, fixing it up, and selling it.
  #39
Old 06-24-2011, 11:44 AM
dave1701's Avatar
dave1701 dave1701 is offline
Good for 100,000 Miles
.They kept getting crappier until they hit bottom and now are china made.
They aren't made now. Are you sure about that?
The Following User Says Thank You to dave1701 For This Useful Post:
Russ2251 (06-24-2011)
  #40
Old 06-24-2011, 12:16 PM
karl's Avatar
I you sure about that?
I thought they still made them in China. Dident know they stopped making them.
