Old 11-04-2019, 09:40 PM
Ramair351 Ramair351 is offline
Default The Zap trike
I bought this 70ís trike a month ago. Someone had already put a 190cc OHV Chinese engine on it. I put a new clutch on it, but doesnít seem to spool up the friction clutch enough to move my 250 lb butt around. It will on flat ground, but if you put a pencil in front of the tire it wonít move. Is the gearing wrong? I think itís 10/60. Do I need more HP? Or RPM?
Thanks for the help! Here are some pics.
E476F4E7-F8CE-4F87-872C-F986D83F949F.jpg   485B6C5D-11D6-4AE5-B9EF-087E3EBABC66.jpg
Old 11-05-2019, 12:59 AM
landuse's Avatar
landuse landuse is offline
Welcome to the forum. With tyres that large, your gear ratio needs to be at least 8 or 10 to 1. You currently have 6:1. And with the weight of you and the trike...it is making it even worse. You are probably going to have to utilise a jackshaft to get compound gear reduction as I doubt a 80T sprocket will work for you
