Go Back   DIY Go Kart Forum > Announcements & Suggestions > Introduce Yourself!
Old 08-30-2014, 01:10 PM
mdog36 mdog36 is offline
Default 1st Go Kart
Hi, i'm 13 and i've decided to build a go kart. I'm pretty mechanically inclined, my only issue is a small budget. I'm planning to spend around $500. I am planning to buy an azusa frame because I have no experience welding. Also, I'm going to use a 212cc predator engine. I'm just wondering, is my budget realistic.
Old 08-30-2014, 01:34 PM
Poboy kartman Poboy kartman is offline
Banned
Welcome to the forum. ..I think so....depending on the shape of the frame.....
Old 08-30-2014, 03:04 PM
landuse's Avatar
landuse landuse is offline
Welcome. Your budget sounds OK to me. What you could also do is buy a roller of Craigslist and build it up from there
Old 08-30-2014, 03:12 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
You're budget is VERY realistic. I use the Azusa frame and is one of the best gokarts out there... a design that goes back to the '60's.
Some folks complain that they are too small...but that is what a true gokart is.
They were not designed for comfort (need a Lincoln for that).
https://www.youtube.com/watch?v=c4jch0puM1A
Old 08-30-2014, 03:17 PM
Banned
Wait.....now I'm confused. ....I thought he said he had 5 Benjamin's. ....and your saying he can get a roomier kart for $5?????
Permission to slap me HARD granted. .....
Old 08-30-2014, 03:33 PM
Russ2251's Avatar
Poboy kartman does'nt carry all his groceries in one bag.
Old 08-30-2014, 05:34 PM
Thanks for the help.
Old 08-30-2014, 05:49 PM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
You can a nice kart for $500.... BUT I think I'd search craigslist.org before I buy anything. I find karts as cheap as $50, then I'd have $450 to "customize" it my way..... Engine=$85-100 tires=$45-100 paint, sandpaper, ect.... =$50.... New cables=$20-30
It could be cheaper........
Old 08-30-2014, 06:51 PM
RiverSideRun RiverSideRun is offline
I bought a good roller of craigslist for 150 everything was perfect. Tires a little worn and needed a new gas tank.
If I had to do it over id but a roller that needs a lot of work and get a honda(or a predator)
I would definitely go second hand frame new engine and clutch or tc
Old 08-30-2014, 07:25 PM
OzFab's Avatar
OzFab OzFab is offline
Just had a quick look at craigslist & there seems to be a miriad of decent karts in your area, someone is even selling a bare Manco AmEx frame for $20 (but I don't suggest you get that one...); go check it out...
  #11
Old 08-30-2014, 09:44 PM
Banned
I'm not as worldly or organized as you Russ.....but this does explain something I was thinking about. .....
You must have some kind of special container you put in your shopping cart. ......because your name came up in conversation. .....and the term "basketcase" was mentioned several times. .......
