  #181
Old 04-26-2019, 08:37 AM
pa17315 pa17315 is offline
Default 2019-Predator Engine Remote Choke part 15
Remote Choke review/testing
The remote choke mod is a great feature for Predator engine 420cc. It is the best improvement so far for this go kart. I can start the engine, control the choke from the driver seat. The choke stop prevent the choke pull from over extend. I can control choke opening as needed for cold engine.
The day of getting in and out is over, call me lazy but if it saves me an annoying trip. I am okay with it.
I would definitely recommend this mod for your Predator engine.
  #182
Old 04-28-2019, 03:04 AM
Corbie Corbie is offline
I have just spent the last hour or so reading this log from start to finish and i must say im impressed, well done to you, the attention to detail is first class. I hope the buggy gets the appreciation it deserves.
  #183
Old 04-28-2019, 09:00 AM
Thank you, not too shabby job right. I am still a newbie but I have learned so much during this project.
The more I have learned, the more I want, the more money it would cost. Now I want, I want, want,,,,want.....a metal lathe, or a mill. CNC...I wish I have never build this go kart in the beginning...
Maybe I can start with a metal lathe from Grizzly. Small one to learn on. Grizzly G0765. I am doing research on it...Seem pretty decent except for the plastic gears.
  #184
Old 04-30-2019, 11:09 AM
Default 2019- Reverse gear box part 1
I have always wanted to install a reverse gear box on Predator 420cc engine.
Briefly look at the part required, It seems like it is a doable project again. However, I am sure some modification to current setup is required. Just a reverse gearbox addition, nothing major, simple but I tend to cringe when the word simple comes up.
We will see, more updates to follow.
If I can do this, then I don't have to get out and push the darn go-kart to turn around again.....The thing is getting so heavy...
  #185
Old 04-30-2019, 04:53 PM
Bansil's Avatar
Bansil Bansil is offline
Waiting for your reverse trial! Been thinking same
  #186
Old 04-30-2019, 06:14 PM
Just looking around, however reverse gearbox for 6hp engine. Predator 420cc is 13hp, it's a crap shoot.
  #187
Old 04-30-2019, 06:26 PM
Default 2019- Reverse gear box part 2
Research:
I found this pic on the web, I am not sure it will work. Looks promising but I don't want to redesign the current setup and then it fails on me.
I may take the plunge but I need to explore possible failures first.
Go Kart Forward Neutral Reverse Gearbox 3-8HP Engine 40/41 3/4'' 10T With TAV30
3-8HP engine!!!!
  #188
Old 05-02-2019, 12:35 AM
Denny Denny is offline
That is too light of a gearbox for your kart and the 30 series won't fare any better than the box.
Keep looking, sorry.
  #189
Old 05-02-2019, 08:40 AM
Yes, definitely too light for predator 420cc. I am sure some folk has done it already.
  #190
Old 05-12-2019, 01:23 AM
russellcorleone russellcorleone is offline
bro, can u give me the plan? i cant afford to buy it
  #191
Old 05-12-2019, 08:52 AM
The basic plan doesn't really apply in my case. It has the appearance of "granddaddy" but much has changed to fit the driver. Your height should be taken into consideration when build. Take the basic plan and enlarge it, width and length on the main frame. front suspension frame should be enlarged. Rear engine frame has enlarged to accommodate larger engine. Beef up shocks, larger tires, electrical system....lots of thing to consider before building. Addition of wheel fender, side steps....emergency brakes...turning lights....
As for the plan, basic "granddaddy" plan is totally different than what I have build. Most of the time, it was sketched out on any kind of paper I have accessed at that moment and then onto build. Sketch out tirelessly and you have less trial and errors.
Use the pics that I have posted to use as a guide and utilize features you like. I can send you pics of area that you have questions.
It's a great learning process, enjoy it.
  #192
Old 05-12-2019, 11:27 AM
Kartorbust's Avatar
The only FNR gearbox that would have worked, was the one from Comet. Not very many float around for sale anymore, pretty much all have been acquired and probably not even used, and will probably be scalped by people on eBay.
  #193
Old 05-13-2019, 10:54 AM
Just check around, you are right, no dice.
  #194
Old 05-15-2019, 01:35 PM
Originally Posted by pa17315 View Post
Printed out the plans, organized different sections, redraw plans with dimensions,
Bro can you share this with me?
  #195
Old 06-19-2019, 10:33 AM
Default Update
I have not been working on the go-kart for a while. I got side track and bought a Grizzly G0752 variable speed metal lathe. I hope this new tool will expand my capacity to make more parts for the go-kart.
I have known that it was a heavy equipment but totally unprepared for the size and weight. I have managed to push, heave, manhandled into my garage, but getting it onto yet to be build table is another matter.
In order to get there, I need a crane. Harbor freight offers a two tons crane hoist or build my own gantry crane with more height, better stability and an option to serve as welding platform. (Example: I can lift the go kart frame, setting it on supports and weld from below. 3 feet off the floor is better than 12 inches.)
To get there, I have found a straight path is not always feasible. There are always surprises and requirements.
If anyone interests, I can post my build as part of this go-kart
