Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
  #41
Old 11-02-2018, 10:38 PM
chados chados is offline
proceeded to assemble the motor.
9EBBAFC4-ECAE-4575-9F63-0087CF63D6BE.jpg   324F8AB4-6E44-42FE-B4A8-1483FCCBBC17.jpg
  #42
Old 11-03-2018, 12:39 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
What am I looking at here?
If that is a scratch in the rod cap, I'd say that rod is junk.
  #43
Old 11-03-2018, 08:42 AM
This is done to supply oil to the central chute. I agree that it looks a bit awful, but we will try it out. Now the piston group with the rod is lightened, the inertial loads hope that they will decrease. Thank you for your recommendations.
Yesterday I washed all the details, today I collected the lower part. I also want to move the coil to install the ignition at 28 degrees, to make the bracket-transfer.
Just ordered a motorcycle motor oil 4t 10w30.
  #44
Old 11-03-2018, 03:48 PM
bob58o's Avatar
Instead of moving the coil, you could rotate the flywheel on the crankshaft. This can be done by installing the flywheel without a key. Many people prefer to run without a key. Use lapping (grinding) compound to mate the crankshaft to the flywheel taper, rotate the flywheel to the position you desire, and torque down the nut while making sure the flywheel doesn't rotate in relation to the crankshaft. It is important to clean the flywheel and crankshaft very well to remove all the grinding compound before installing the flywheel. The same type of grinding compound used for the valves also works on the flywheel.
Another option is to file the top part of the key. It is easy for me to purchase an "offset" key here in the States, but it is not difficult to make one either. Every 0.010" (0.25mm) filed off = 1.3 degrees of timing advance. So around 1mm filed off the key is about 5 degrees of timing advance.
  #45
Old 11-08-2018, 06:22 AM
Thanks bob58o! So we will do it, I plan to set 28-30 degrees ignition advance.
Can you please tell me if I can find the characteristics of the standard camshaft gx200? We want
INTAKE
OPEN: CLOSE:
EXHAUST
OPEN: CLOSE: ?
  #46
Old 11-09-2018, 10:16 AM
Today, when assembling the head, I discovered that I have different springs, one 29mm another 30.5mm.
I had doubts, it seems the spring 29mm - weak weakened.
What should be the size of the spring? According to my information, the height should be 31mm.
  #47
Old 11-11-2018, 07:44 PM
Assembling the head, as well as delivered winter tires.
The Following User Says Thank You to chados For This Useful Post:
landuse (11-11-2018)
  #48
Old 11-13-2018, 12:24 AM
bob58o's Avatar
Quote:
INTAKE
OPEN: CLOSE:
EXHAUST
OPEN: CLOSE: ?
That's a tough one. I haven't been able to locate the specifications myself. BUT the closest thing to a stock camshaft that I can find the specifications for is a CL1 grind camshaft. It has the same lift and duration of a stock cam, but I suspect the cam timing is retarded a bit (meaning the valves open and close later) to push the peak HP to a higher RPM range.
Specs for CL1 grind...
Target (MAXIMUM) RPM = 5200 - 5800 RPM
Ignition Timing = 32 degrees Before Top Dead Center
Intake Open (from seat) = 43.0 degrees Before Top Dead Center
Intake Open (0.050" Lift or 1.27mm) = 0.9 degrees Before Top Dead Center
Intake Close (to seat) = 76.5 degrees After Bottom Dead Center
Intake Close (0.050" Lift or 1.27mm) = 37.7 degrees After Bottom Dead Center
Intake Lift = 0.224"
Intake Duration (0.050") = 219.0 degrees
Intake Center Line = 108.5 degrees After Top Dead Center
Exhaust Open (from Seat) = 80.5 degrees Before Bottom Dead Center
Exhaust Open (0.050" Lift or 1.27mm) = 39.9 degrees Before Bottom Dead Center
Exhaust Close (to seat) = 41.0 degrees After Top Dead Center
Exhaust Close (0.050" Lift or 1.27mm) = 2.2 degrees After Top Dead Center
Exhaust Lift = 0.231"
Exhaust Duration (0.050") = 222.5 degrees
Exhaust Center Line = 110.0 degrees Before Top Dead Center
A CL2 grind cam shaft is retarded about 4 degrees from the CL1. Otherwise, it has the same lift, duration, and lobe separation angle as a CL1 and stock camshaft. The Intake Center Line on the CL2 is 112.0 degrees After Top Dead Center. The Exhaust Center Line on the CL2 is 105.5 degrees Before Top Dead Center. Retarding the cam those ~4 degrees moves the target (Maximum) RPM to 6200 - 6800 RPM.
A CL3 grind camshaft is retarded another 2 degrees from the CL2. Lift, Duration, and Lobe Separation Angle are the same as a stock, CL1, and CL2 camshaft. Intake Center Line is 114.0 degrees After Top Dead Center. Exhaust Center Line is 103.5 degrees Before Top Dead Center. Target Maximum RPM for a CL3 is 6400 - 6900 RPM.
All three of those cams recommend 32 degrees Before Top Dead Center for Ignition Timing.
Specs from the manufacturer can be found Dynocams website.
https://www.dynocams.com/item/cl1/
https://www.dynocams.com/catalog/doc...ynoCamsCL1.pdf
  #49
Old 11-13-2018, 10:43 AM
Thanks, I will study the information. so far we have put a standard shaft for running the engine. Today I installed the cylinder head, adjusted the valve, installed the coil, the casing, and also made the key -1.1mm. left to do crankcase ventilation.
6A694837-E3C7-4CBE-B540-1AC808B2EC77.jpg   FBDDE243-C4D0-491F-B272-4D8680AA6CAE.jpg
1DE5BB90-EB58-4056-87C5-BCB62DFCF89C.jpg   BAA195D8-70CD-4713-9D51-C724BDE50F6A.jpg
landuse (11-14-2018)
  #50
Old 11-14-2018, 12:38 AM
landuse's Avatar
landuse landuse is offline
Looking good!
  #51
Old 11-15-2018, 08:02 AM
today got motor oil.
  #52
Old 11-18-2018, 08:32 AM
Today, made the first launch of the motor.
landuse (11-19-2018)
  #53
Old 11-28-2018, 08:37 AM
Bought studded ice tires. 60 spikes in the wheel.
61AD3AF9-E27D-4C61-8391-027ED42DD049.jpg   941B97DE-3C44-45A5-B88E-745EC4AB5BDC.jpg
  #54
Old 11-28-2018, 09:12 AM
karl's Avatar
karl karl is offline
Those are awseome! I need a set!
Probally not cheap. Maybe should just stick with carlise x-tracs.
The Following User Says Thank You to karl For This Useful Post:
chados (11-28-2018)
  #55
Old 11-28-2018, 09:54 AM
In Russia, a set of tires costs $ 87.
  #56
Old 12-10-2018, 09:23 AM
Hello dear forum members! I havenít written anything for a long time, I was busy with the main work, for the past time, I changed the new tank and put it on my feet, installed winter tires, almost fixed the pump, I still need to supply fuel. I will try to deliver the weekend and arrange a test drive.
  #57
Old 12-10-2018, 11:49 AM
LightningTeg's Avatar
LightningTeg LightningTeg is offline
Studded snow tires sounds like a good time in the winter
  #58
Old 12-11-2018, 12:35 AM
landuse's Avatar
Those tyres look so cool mounted to the kart. How well do they work?
  #59
Old 12-11-2018, 08:58 AM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
Frozen lake racing looks to be in your future. I'm mildly jealous.
  #60
Old 12-15-2018, 10:02 AM
Today completed the work on karting.
Installed the necessary parts and protection from snow. Made a test run, winter tires work well, but you need to adjust the carburetor.
Closed Thread
