Reply
Old 01-13-2020, 12:58 AM
Shax90 Shax90 is offline
Default Predator 212 muffler
Anybody know how to make a decent sounding DIY muffler for a predator 212?
Old 01-13-2020, 08:35 AM
txluke txluke is offline
Cut the flange off the stock muffler and weld a 1" 90 ENT electrical conduit on it. Cost - $4
The Following 2 Users Say Thank You to txluke For This Useful Post:
mckutzy (01-13-2020), Shax90 (01-13-2020)
Old 01-13-2020, 08:44 AM
Quote:
I appreciate the help!
Old 01-13-2020, 09:29 AM
mckutzy mckutzy is offline
Could be free if your good at scrounging...
I know I did one day.. and came up with something similar... Also out of EMT...
The Following User Says Thank You to mckutzy For This Useful Post:
Shax90 (01-13-2020)
Old 01-13-2020, 11:05 AM
I already had this so it was free. I assume the average person isn's a junk hoarder like me and will just buy one.
Old 01-13-2020, 03:41 PM
The title above says DIY... Usually that means... Were all junk hoarders... Of some sort...
  #7
Old 01-13-2020, 03:49 PM
gegcorp2012's Avatar
gegcorp2012 gegcorp2012 is offline
I started with a header pipe, but sectioned it and added a pipe fitting that allows me to screw on a 13HP 'sausage' muffler.
The muffler sounds better than stock, but not as loud as the pipe alone.
BTW, I also did the other stage 1 mods, a better flowing air cleaner and jet (not shown in photo)
Sent from my SM-J700T using Tapatalk
The Following User Says Thank You to gegcorp2012 For This Useful Post:
Shax90 (01-13-2020)
  #8
Old 01-13-2020, 04:57 PM
Thanks! If my engine has less horsepower is it okay to use a higher horsepower muffler? I'd assume so but I want to make sure
  #9
Old 01-13-2020, 05:38 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Using a muffler from a bigger engine(heck, even a car muffler) is a good way to keep power high while muffling. So yeah, no problems there.
Currently Flathead-Crazed
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Shax90 (01-13-2020)
  #10
Old 01-13-2020, 07:18 PM
Heres a link to a video with sound if you want to hear it. Skip to the end where I am staying close to the camera (phone). When I am holding the phone and going more than 20 mph, you hear the wind
https://youtu.be/YlGP0D15dGM
  #11
Old 01-14-2020, 02:26 AM
Jhoppe Jhoppe is offline
Hey gegcorp, could you post a link to that muffler you used? That application is very similar to mine and I need to quiet it down for my boys.
  #12
Old 01-14-2020, 08:21 AM
I got it at the local Tractor Supply Co, but other big box stores may have similar items... here is a snapshot of the item from the TSC online store:
Shax90 (01-14-2020)
  #13
Old 01-14-2020, 01:33 PM
Do you guys think this would do well? I'd like to keep it as quiet as possible because of sensitive neighbors. Predator 212 I realize it's big but I'm hoping that will keep it quiet
  #14
Old 01-14-2020, 02:16 PM
Oh ya itll help to keep it quiet... It just big thats all...
Bigger question is(pardon the pun... ) Do you have space for it and the bracketry to support it properly......
  #15
Old 01-14-2020, 02:35 PM
I can fit it but how you you recommend supporting it like are there certain brackets I should get or would Jerry rigging be fine😂
  #16
Old 01-14-2020, 03:45 PM
Cant really say, till I see what is it going into...
However to get it done... remember if the motor needs to be moved for tensioning of a chain... the exhaust needs to be allow to move aswell, if supported along its length from the motor attached to the frame( like in a car, with rubber mounts).
Some have made mounts that attach to the valve cover bolt or a bracket attached to the PTO mount... Even from the top brackets with those without a gas tank installed...
  #17
Old 01-14-2020, 06:54 PM
That's the bike I've got to move the vertical part of the frame forward a tad to fit the predator. Think I could do some sort of bolting system where a brace comes off the muffler and bolts to the frame? And if I have to take it off I'd just take the bolt out?
  #18
Old 01-15-2020, 12:53 PM
ForceFed86 ForceFed86 is offline
Mower mufflers flow and sound like garbage.
Grab a china scooter/dirtbike muffler off ebay. They have a great deep tone. Can get them for 10$ shipped. Just takes awhile! lol
The Following User Says Thank You to ForceFed86 For This Useful Post:
Shax90 (01-15-2020)
  #19
Old 01-15-2020, 03:46 PM
Smerft85 Smerft85 is offline
You have NO IDEA!!! 😁
Reply
