Reply
Old 12-20-2019, 11:58 AM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
Default I've found the answer, I think
I think I may have found the answer for putting lighting coils on a predator. This:
https://www.gopowersports.com/cranks...2cc-tillotson/
It's a tillotson 212 crankshaft, so I'd think it should fit in a predator, but it says in the description:
Quote:
The KD212-1275 is the stock OEM crankshaft assembly for the 212cc Tillotson Engine (blue), with a 54.94mm (2.165") stroke. This Crankshaft accepts the clone/honda flywheels and connecting rods but has .040" more stroke then the 196/200's which makes this crank a cheap and easy way to produce more power.
So it accepts Honda and clone flywheels (according to GPS), which come with lighting coils.
For his personal safety, keep this one away from bicycles.
Old 12-20-2019, 12:35 PM
itsid's Avatar
itsid itsid is online now
you may still have no threaded holes to mount the actual coils in your predator.
the IMHO correct solution is to buy a rato p210-III with e-start
since that IS what HF sells you as a predator.. well with e-start of course and thus lighting coils
Old 12-21-2019, 12:21 AM
J.S.@SMS's Avatar
Road Hazard
Now that has me wondering. I might pull the flywheel off one of my predators to see. But I remember that the low oil sensor mounting holes were tapped on my minibike which never had a low oil sensor (should be a rato if I remember). I have a non hemi that’s just sitting on a shelf that I’ve been meaning to re lap the flywheel on, since when I got it, it came on a kart that was sitting out in the rain without a muffler (there is a slight water stain halfway up the bore, but I can’t complain since it came with three karts for $300).
Old 12-21-2019, 10:46 AM
Flyinhillbilly's Avatar
Flyinhillbilly Flyinhillbilly is online now
The great cornholio
I have one on my bench wit the flywheel off. The holes are tapped on my hemi. I havenít paid any attention to any of the others Iíve had apart.
You can't drink all day if you don't start in the morning
The Following 2 Users Say Thank You to Flyinhillbilly For This Useful Post:
itsid (12-21-2019), jmaack (01-13-2020)
Old 12-21-2019, 11:57 AM
itsid's Avatar
good to know..
I'm not sure if rato always had a e-start p210 or if that was a more recent addition.
but as long as 'some' are it's at least a chance..
Now all there's left to do is find a US supplier for rato spare parts I think
PS the first tillotson were Ducar engines IIRC.. a 212 Ducar with e-start isn't too hard to find
really so that's still a very easy solution as well
Old 12-24-2019, 03:45 PM
Smerft85 Smerft85 is offline
Quote:
I watched a YouTube video of someone adding the coils to a predator, if I remember correctly it was the non hemi and it had the threaded holes just like that.
  #7
Old 12-24-2019, 07:58 PM
itsid's Avatar
My concerns were most a matter of age than a mater of headshape
I don't know if rato added e-start to their p210s recently or they always had an e-start 212 engine..
I know the p200 (196cc) always had an e-start option, I wasn't sure about the p210s
since there's little to no solid infos out there.
I'd say a fresh out of the box predator should be tapped... one you bought a few years ago... I have no clue!
So my best advice would be:
if you intend to try, take a quick peek under your flywheel just to be sure first
  #8
Old 01-13-2020, 09:13 AM
txluke txluke is online now
Take the coils and flywheel from a clone and use them on a non-hemi 212. The flywheel taper is just slightly off but 5 min of lapping and it fits perfect. Don't forget to check and adjust your coil gap if necessary. I have done this on 3 different engines. The best source of coils and flywheels is off of a Baja warrior or Coleman ct200u-ex. People are always swapping predators on them.
The Following User Says Thank You to txluke For This Useful Post:
gegcorp2012 (01-13-2020)
Reply
