Go Back   DIY Go Kart Forum > Other Stuff > More Builds
Old 08-13-2019, 03:20 PM
KartFab's Avatar
KartFab KartFab is offline
Default Winch in Ground
So i may have ran over our neighbors grass a time or two, and my wife may have taken out our fencepost.
This leads me to exhibit A. Winching the trailer up our weird, steep, and wonky driveway.
I took some leftover 1.5"x3"x14ga square tubing from a previous table build for a customer (back when i used to do welding for people). And a little bit of flat plate and, 8-10 bags of concrete, and a fencepost, and a 10,000 lb winch.
Trailer mover didnt work, because of the incline, and i had already used it, so im just using trailer mover on the tongue, and welded some D-rings to the FRAME of our little camper. Yeah, we got it used, and there is no warranty so whatever.
3/8" cable from home depot attached to the d rings with two clips and a snatch block so we can pull from any point and still steer it.... Lo and behold, it actually worked!!!
Old 08-13-2019, 03:22 PM
KartFab's Avatar
And there it is. Frame hasnt bent, winch hasnt popped off, and we can steer this little guy into the side yard without running over the precious grass, or our fence (again).
Old 08-13-2019, 04:20 PM
Kartorbust's Avatar
Very nice! Driving a truck and trailer in a driveway is not the easiest thing to do at times, so I understand the grief that it gives you.
KartFab (08-15-2019)
Old 08-13-2019, 05:02 PM
mckutzy mckutzy is offline
Interesting build....
I fricken hate that galv paint... brutal smell....
I dont know whats worse off Spraying zic paint or welding galv...
Old 08-14-2019, 01:06 AM
Tpdingo Tpdingo is offline
One will kill your nose and one will kill you. Pick your poison.
Old 08-14-2019, 01:34 AM
landuse's Avatar
landuse landuse is offline
Very ingenious!!
Old 08-14-2019, 09:45 AM
Well...MFF will make you feel like you want to die...I know..
So with this winch.... What is the long bar out the back for??
I see it doesnt swivel so I ssumed it was for a pivot, but it doesnt..
Old 08-15-2019, 07:34 AM
KartFab's Avatar
i was worried about the concrete support working loose over time (e.g. rocking back and forth) its just over-engineered. The idea was to have a lower point to "anchor" the winch down as it pokes out of the ground a bit. trailer is about 3,000 lbs.
Old 08-15-2019, 11:49 AM
Ohhh I see.. Ya I guess thats a bit stout.... It might move a bit later on...
