Reply
Old 02-09-2020, 01:05 PM
karl karl is offline
Default How to DOUBLE your China clone's Power
Should I throw $30 into this for a double row #40 chain coupler? Rest must be used/junked parts and scrap in the garage.
Two junkyard 208's = 416cc
Old 02-09-2020, 01:10 PM
Tpdingo Tpdingo is offline
If you give 8 to 805roadking, you'll come out with a 1.6l v8!
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
Old 02-09-2020, 01:29 PM
mckutzy mckutzy is offline
That would be cool if you could get the pair to work together.....
Obviously getting the two in sync will be the greatest challenge, aswell as having the correct firing position of the opposite coil...
Im told its doable to make a custom ignition wire so you will have the length needed...
Youll need to come up with a custom air ducting and a more firm permanent joining mounting plan.
Id suggest a flex Lovejoy coupler for the two shafts, to minimize the interference of the shafts axial misalignment.
I wonder how DIY this could be done???
Old 02-09-2020, 01:40 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
I want to see you do this!
And then hook it up to a converted Comet FNR gearbox to have 2 speeds!
Currently Flathead-Crazed
Old 02-09-2020, 01:50 PM
Yes, of course they will work as a pair
The other coil, 180 degrees out, will be adjustable, and a jig that fits tight on the #1 coil will set base timing for coil #2 , and just extend the coil wire out.
As far as cooling, cooler burning fuel
The motors mounted on a stiff base, then a girdle on top the blocks, and a cage around the coupler, connecting side cover to the 4 charging coil studs , ect.
The more rigid the blocks are connected, the less misalignment there will be from vibration
I got this, no worries
ChargerMiles007 on youtube will give you an idea, but his vibrate like crazy, only connected at base of motors.
This will idle and be put under load.
Jt, that's getting out of budget! Haha would fit the theme
Old 02-09-2020, 08:09 PM
Quote:
Alright, I think the L100 lovejoy should be sufficient, 22hp at 3450 rpm.
So the budget is spent!
The Following User Says Thank You to karl For This Useful Post:
mckutzy (02-09-2020)
  #7
Old 02-10-2020, 05:24 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
I wanted to make some kind of smart reply lol but this is too cool to do that on.
I gotta fix my flathead collection
  #8
Old 02-11-2020, 06:37 PM
Motors assembled,governors deleted, blocked off dipstick, shafts ground, no hemi's
I am missing a valve cover, springs, and I noticed a valve rusted up. So stock cyl heads it is
landuse (02-11-2020)
  #9
Old 02-13-2020, 11:04 AM
The coupler is massive! I cut one side down, one to go.
  #10
Old 02-13-2020, 11:49 AM
Aka a kenbar
This thing will be a pain to pull start lol
  #11
Old 02-13-2020, 04:17 PM
Quote:
Naahhh she'll be right
motors are stock, will run single gx390 carb
I upped the budget $6 and bought a matching valve cover. Cant decide, polish the old one, or rust the new one
  #12
Old 02-13-2020, 06:07 PM
itsid's Avatar
itsid itsid is offline
rattle can pink both
  #13
Old 02-13-2020, 07:42 PM
Aka a kenbar
Yes that is required sid
  #14
Old 02-13-2020, 11:06 PM
landuse's Avatar
landuse landuse is offline
Rust the other one
  #15
Old 02-14-2020, 07:57 AM
Pink haha Ill compromise, since I already glued the covers on with SI 5900 instant gasket, ill grab a can of paint and cut off wheels for the base tonight.
The engine cover and base will be pink.
  #16
Old 02-14-2020, 09:53 AM
Aka a kenbar
Thad be fun
  #17
Old 02-14-2020, 08:26 PM
Thad be fun
Fun? maybe. Pink? Very
The Following 2 Users Say Thank You to karl For This Useful Post:
Budget GoKart (02-15-2020), itsid (02-14-2020)
  #18
Old 02-14-2020, 09:04 PM
itsid's Avatar
uhhhh now.. where to get a Barbie sticker these days?
PS I was just kidding.. but now I kinda like it.. +1 vote for "Fun"
  #19
Old 02-18-2020, 07:53 PM
Quote:
Thanks , I got some decals on the way
  #20
Old 03-15-2020, 04:57 PM
itsid (03-15-2020)
Reply
