Go Back   DIY Go Kart Forum > Build Contest > Did not Finish Logs
Closed Thread
  #41
Old 03-02-2017, 07:09 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
You said this is all Getting Huge.
I like your thinking out of the Box...
But would it be better to just get a Horizontal Shaft Predator?
Why don't you, go back to your double wide and fry something!
  #42
Old 03-02-2017, 09:22 PM
pRoFiT's Avatar
pRoFiT pRoFiT is offline
Can't buy it?, build it!
if i was building a go kart or a mini bike yah. But for this i want the powered wheel to be the steering wheel. if i had Horizontal i would have more problems.
Could maybe just take mini bike rear end and stand up, add steering to frame. Done... maybe. add throttle to steering wheel.
Think of bumper car steering. Where you steer where you want to go. but faster
2016 diygokart Contestant http://www.diygokarts.com/vb/showthread.php?t=33422.
  #43
Old 03-13-2017, 10:50 PM
pRoFiT's Avatar
Okay it's been a while since i've posted updates. been busy.
so i have a couple posts.
First here is a possible layout of the parts i have so far.
Needs to be cut down. so that's what i did.
  #44
Old 03-13-2017, 11:00 PM
pRoFiT's Avatar
So off to cutting down and cleaning up the steering/axle assembly. I shortened it down about 1" to 2". Will need to cut the axle down too. The axle is currently 14" i'm thinking 10" after i cut it down.
  #45
Old 03-13-2017, 11:14 PM
pRoFiT's Avatar
So the hole cutting set is coming in handy. Cut my sprocket to fit the 1.5" steering pipe.
From the excess parts i cut off the steering assembly and modified(bent with hammer) the spacer pipe until it fit snug against the steering pipe. then ground open my sprocket to fit tight. Will need to partially weld and add nut/bolt so i can fasten it down. should be keyed...but im not sure how to add that...will not be good to have steering slip. So will need to figure something out with this.
  #46
Old 03-13-2017, 11:19 PM
pRoFiT's Avatar
Out on a junk scavenge today I found a huge pile of bikes! Great score. found enough with the same sprocket and teeth count. 18T. So i pulled 4 bikes apart to get the sprockets. 1 had 16T ugh....oh well i only needed 3 more. so now i have enough for my steering system! yay me.
  #47
Old 03-16-2017, 11:43 PM
pRoFiT's Avatar
Worked on the internal frame today. Cut my steering jackshaft hole to big. Need to weld a ring in place. Should be ok. Need to cut the top piece and then i can tack weld it together.
I have a 6' piece of 3" square tube that i can use for the top. Will need to cut it to size.
  #48
Old 03-23-2017, 08:54 PM
pRoFiT's Avatar
When you are welding a frame, it is a good idea to spot weld before fully welding up a frame. Thankfully this is what i did. because after i welded the first part of the frame to the steering chassis i did it upside down as you can see in the image and the reference drawing behind it.
Click image for larger version
So a couple spot welds removed and good to go.
Then i welded up the top part of the steering bracket. It holds but not great. Will need to put set screws in the side maybe? I would weld to steering but i may need to remove later. so i have to do it this way. And no room for a key on the shaft.
ID:	83102 Click image for larger version
And the semi completed internal frame work. Still a ton of welding to do
Sorry looks like i had some bad lighting. I will take some new ones and replace maybe
  #49
Old 03-23-2017, 10:09 PM
6.5hp's Avatar
6.5hp 6.5hp is offline
dude what are you actually making????
  #50
Old 03-23-2017, 11:52 PM
pRoFiT's Avatar
Quote:
I don't know. Art? lets just follow along and see I cant wait to find out myself.
  #51
Old 03-24-2017, 12:07 AM
pRoFiT's Avatar
So tonight i worked on the steering transfer gears and axle mounts. you can see before and after on the sprockets.
Still need to build key slots into them. Going to be a long day of filling i think. but they look like they fit okay and are fairly straight.
Will need to add another sprocket to tighten chain. it's not that tight and it hangs. so a tensioner will need to be designed or purchased
ID:	83112 Click image for larger version
What am i building??? maybe i should start another thread where people can guess what this is
Even my wife was in the garage today and said what is this for again?
  #52
Old 04-11-2017, 12:31 PM
pRoFiT's Avatar
I did some work a week ago and never posted it. As you may know i got a couple mini bikes and they are keeping me busy
I needed to take off the lawnmower blade mount on the engine shaft im using. I picked up some PB Blaster to loosen up the parts...
....well this was going to take a while and im not a patient man.
So i cut the thing off.
ID:	83503 Click image for larger version
Now the clutch fits but i still have the pulley mount on the shaft...Think this is going to be a problem? should i leave it on in case i want to use it? like generator pulley connection for lights?
ID:	83505 Click image for larger version
Or is it going to make an unstable clutch since it's not all the way on?
  #53
Old 04-11-2017, 12:39 PM
pRoFiT's Avatar
...Oh and I also made the other side of the steering bearing mounts have edges. i only had one side done and it seemed like it was going to work okay so i modified the other side to be the same.
ID:	83507 Click image for larger version
Then i also worked on the actual steering wheel axle and gear. Used a 5/8" collar and bicycle gear to complete the needed gears.
Once welded in place i used a file and created a keyway. There is a gap in the images but i went back and welded up the outside of the collar to eliminate flex on the keyway opening.
ID:	83510 Click image for larger version
Thinking another week or two on the mini bikes and i will get back to this project. It is a 2017 build off. Don't want to be done too early.
  #54
Old 04-20-2017, 12:18 AM
pRoFiT's Avatar
I think i found my seat for the krazy kart. May need the cloth replaced with some leather. But i may just keep as is.
  #55
Old 04-20-2017, 12:29 AM
6.5hp's Avatar
Quote:
Originally Posted by pRoFiT View Post
Attachment 83505 Attachment 83506
just mount it backwards
like this
  #56
Old 04-20-2017, 12:53 AM
pRoFiT's Avatar
like this
I can't. It is 1" bore and does not go all the way through at 1"....think because it's 10T they had to design it smaller at the sprocket. I may just mount engine a little higher than planned. Use the pulley for generator, lights.
P.s. that image... Looks like they added another adapter as well to make it work...
  #57
Old 09-15-2017, 01:58 PM
pRoFiT's Avatar
Okay it's been a long time since i worked on this. California weather has been FREAKIN HOT all summer. So im thinking i need to get back out in the garage now and try to finish this thing. or at least try to make it work.
So i was thinking i need a (suicide\brodie) knob to make steering easier. since i wont be able to see tire direction .... posibly...i can have the knob an forward direction and it will help me direction this krazy contraption.
So i picked this up for $5 on ebay a month ago.
It just came in this morning. i thought was wood but is plastic wood? WT? anyways. now i need steering wheel to go with it.
  #58
Old 09-17-2017, 08:02 PM
Kansaskart Kansaskart is offline
That's hillarious!
The Following User Says Thank You to Kansaskart For This Useful Post:
6.5hp (12-19-2017)
  #59
Old 01-15-2018, 03:00 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
Post updates!
  #60
Old 02-20-2018, 01:14 AM
pRoFiT's Avatar
Quote:
Originally Posted by robertdjung View Post
Post updates!
LOL
Um busy. No updates. still same as last post. Life comes at you fast some times. Was planning on cleaning up garage and continuing. Just noooo free time.
Closed Thread
