Closed Thread
Old 09-03-2010, 08:42 PM
NapO NapO is offline
Default Gx160 vs LIFAN 125CC Motor Engine
This is for all the bike engine believers lmao, i currently have race modified gx160 on my off road kart. i was looking on ebay and stumbled upon some dirt bike engines. i would like to make my kart a shifter and was wondering if the LIFAN 125CC Motor Engine would be a good prospect. it has 4 manual gears including reverse. althought in the pictures i see alot of wiring and stuff. so that leads me to ask would that all have to be hooked up? the only wiring on my kart is wired out kill switch. also what gear ratio would i run with this engine? right now i have a 12 tooth cvt on with 61 tooth on the axle. thanxs. im new to bike engine but experince with gx160 engines if that helps at all.
Old 09-03-2010, 08:46 PM
fowler's Avatar
fowler fowler is offline
the bike engine is this much better
the bike enginee may have more outright hp and it has a gear box
That's not an oil leak
It's horsepower sweat
Old 09-03-2010, 09:03 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
yes, unless the engine your buying comes with this stuff you will need a wirirng harrnes, carb, exuahst, cdi, air filter, and more, some one here prob has a list of everything. this site has good prices, most of there engines include most of the things you need to get your engine running. http://www.tboltusa.com/store/engine...c-114_119.html
Old 09-04-2010, 03:55 PM
mike75925's Avatar
mike75925 mike75925 is offline
thinker and tinkerer
the chinese quads dirtbikes etc, can do about 40 even if they are single speed. it feels that way anyway. that's on a 90cc engine. the manuals and semi autos can go a bit faster. if you know what you are doing with an engine, i would suggest buying one from a scrap yard or elsewhere. from scrapyards, they can generally be had for less than what a hf 6.5 goes for. since beginning work on these, electrical problems are almost a given on the ones with remote start/alarm; the pulse coil mount breaks on the old style honda clones (110 style motors); and the cam chains/piston rings on both the 110 and gy6 style motors. getting more power out of these motors can be more expensive than the hf clone parts. for instance, they sell a 4 valve head for the gy6, that i want to say is around the $200 dollar mark. but, a no rev limit cdi is around 20.
deo non fortuna
Old 09-04-2010, 04:47 PM
r97's Avatar
r97 r97 is offline
oops, i always forget about junk yards because i have none near me(), but yea if you can fix an engine a used one is the way to go!
Old 09-04-2010, 04:51 PM
KieranM's Avatar
KieranM KieranM is offline
Doin It!!
lifan is a china company as stated by mike, so bare in mind, unless you can find the engine its based on, parts will be hard to find. Also diagrams and wiring diagrams are very hard to locate
  #7
Old 09-05-2010, 09:10 PM
coolkarter's Avatar
coolkarter coolkarter is offline
gx160!!!! its twice the size
  #8
Old 09-05-2010, 09:23 PM
fowler's Avatar
its half the size in hp and only slightly bigger in displasment
how is is twice the size
  #9
Old 09-05-2010, 09:39 PM
r97's Avatar
r97 r97 is offline
gx160 also doesn't have gear box.
  #10
Old 09-06-2010, 02:58 PM
KieranM's Avatar
Doin It!!
not twice the size
125cc-160cc
  #11
Old 09-06-2010, 04:47 PM
Rotore Rotore is offline
Teh SPIK
most lifan engines are honda ohc clones so parts and aftermarket avalability is fair.
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
  #12
Old 09-07-2010, 03:42 AM
brendonv's Avatar
brendonv brendonv is offline
Lifan for sure. Have one on my pit bike and it goes about 110km/h and pulls monos in 1st. Wayyyyy more power then a modded gx160. They are clones of honda crf motors and parts are easy to get on ebay everywhere. Look in the paper and stuff though coz i can pick up 3 of them for about 80AUD second hand.
www.youtube.com/brendonv101
www.youtube.com/SeeAustralia
  #13
Old 09-07-2010, 08:39 AM
mike75925's Avatar
the 125cc engines aren't as common as the 50cc, 70cc, 90cc and 110cc engines.
deo non fortuna
  #14
Old 09-07-2010, 11:37 AM
Teh SPIK
true not as common but parts are avaliable
  #15
Old 09-13-2010, 11:08 PM
im thinking of building a mini chopper and im gunna probally use either 125cc or 150cc for the motor. i figure i'll just leave my kart alone . off topic but how hard is it to make a mini chopper street legal for use in ontario, canada?
  #16
Old 09-14-2010, 04:59 AM
Wim's Avatar
Wim Wim is offline
Jazz Maverick
Quote:
Hey brendonv, where did you see those? I was looking around for cheap bike engines here in Perth and came up with nothing. Sort of what made me build the gearbox for my kart instead. If I'd been able to get my hands on a 125cc with gears for $80 I would've snapped it up.
  #17
Old 09-14-2010, 05:23 AM
fowler's Avatar
your best bet would be a bike shop as there is a butt load of cheap chinese quads running around these days
go and see if they can order one in for u as it would be cheaper than ordering it your self (maybe)
  #18
Old 09-14-2010, 08:38 AM
modelengineer modelengineer is offline
Lord of the noise
Written off bike auctions:
http://www.manheimfowles.com.au/
http://www.pickles.com.au/
I don't think you'll find one for $80 outright, but once you sell all the parts you don't need you should be able to get the engine, brakes, sprockets, chain, etc for free, if you pick the right bike. Maybe even make some money on it.
Andrew
GS500F powered...
The Following User Says Thank You to modelengineer For This Useful Post:
Wim (09-14-2010)
  #19
Old 09-14-2010, 11:32 PM
Wim's Avatar
Wim Wim is offline
Jazz Maverick
Thanks for the links, sorry for the thread hijack.
  #20
Old 09-22-2010, 08:47 PM
hey im really considering the mini chopper project do u think i should go 150cc or the 200cc lifan remember im considering making the road legal. anyone no how hard it is to get a mini chopper road legal? also, are these engines hard to set up?
Closed Thread
