Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 04-28-2010, 11:38 PM
newrider3's Avatar
newrider3 newrider3 is offline
Default rat mower
Got this heap for free last weekend. Still debating fixing it up/selling or building a racer. 18hp Opposed Briggs, and a 2spd (lol) transaxle. I already ripped out all the extra wiring and redid it with a simple starter button and kill switch.
The seat was basically rotted off, so it has an awesome leather cover now (aka welding apron). Also the airbox lid was missing, so an old license plate and some zipties later, here it is.
Also a quick chop of what it could look like:
Don't let your keyboard write checks that your a$$ can't cash.
Old 04-29-2010, 03:01 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Not worth fixing IMO, i'd just make it a rat racer/offroader.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 04-29-2010, 04:10 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Definitely lower and gear up.
Old 04-29-2010, 05:28 PM
Doc Sprocket's Avatar
Rat all the way!!! Needs some velocity stacks, or zoomies or something.
Old 04-29-2010, 09:12 PM
newrider3's Avatar
Guess I made up my mind; I flipped the front axle today. I'm gonna be scraping everywhere. Lowest point is like 1" ground clearance
Old 05-01-2010, 07:35 PM
newrider3's Avatar
So, I spent some time today building a dual exhaust set-up. (ignore the baling wire, temporary)
Get it running, and notice that only one cylinder is blowing hot, the other is blowing cold/SUCKING. Pull the head, breaking off a bolt inside the block (fvck), and see this.
  #7
Old 05-01-2010, 08:41 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Nice work on the exhaust.
  #8
Old 05-01-2010, 08:51 PM
Pro Junk Collector
bummer dude...
  #9
Old 05-01-2010, 08:54 PM
He//, that sucks! Guess you've got your work cut out for you, eh?
  #10
Old 05-01-2010, 09:54 PM
freakboy's Avatar
freakboy freakboy is offline
the names 'mater
jb weld to the rescue
  #11
Old 05-01-2010, 09:58 PM
t0x1k's Avatar
t0x1k t0x1k is offline
Vroom
Drill it out, tap it with a heli-coil, get a new valve and seat and call it a day.
RIP HoffCo/Comet Industries 10/20/2009
This is a sad day for the karting and mini bike industry
  #12
Old 05-02-2010, 09:46 AM
freakboy's Avatar
the names 'mater
hey u should do a suicide front axle! like every other rat rod!
  #13
Old 05-02-2010, 08:14 PM
Quote:
That's just be sweet!
  #14
Old 05-02-2010, 09:59 PM
newrider3's Avatar
Can any of you guys identify this transaxle? 2 speed with reverse; upon disassembly I found that it is a 1" axle riding on sealed needle roller bearings, and the gears ride on sealed bearings as well. Should be pretty stout?
I've already removed all the grease and cleaned the cases/internals (after the pics), so I would use gear oil now correct? Also, what is going to happen if I leave the reverse chain in? Is that something which will severely limit its life?
I also stripped the mower down most of the way today. Took the motor off so I could get a better look at what parts I need to replace. Also took a pic showing the planned ride height (sorry it's so blurry):
  #15
Old 05-03-2010, 04:25 PM
freakboy's Avatar
the names 'mater
looks pretty good!
  #16
Old 05-03-2010, 05:30 PM
That's going to be really cool. Leave it all rusty and ugly! Can you explain the axle flip thing?
  #17
Old 05-03-2010, 06:02 PM
Kartless....
The reverse chain should at least be replaced with a new one. Racers remove em because they don't need it and if it breaks, it tends to wrap around the sprocket and blow the case open.
  #18
Old 05-03-2010, 06:24 PM
newrider3's Avatar
Quote:
I took the original mower axle tube off, and put it back on the mower upside down. I had to notch the front of the frame to clear the tie rod, and add a new tab for the drag link from the steering gear. Sets it a ton lower (almost too low, but w/e it was easy and free).
  #19
Old 05-03-2010, 06:29 PM
Neat mod! But what does that do to caster, camber, and KPI?
  #20
Old 05-03-2010, 08:26 PM
newrider3's Avatar
No change, plus it's not like these were built with the utmost precision in the first place.
Closed Thread
