Reply
Old 10-22-2019, 08:30 PM
Bmr4Karts Bmr4Karts is offline
Default How well do one wheel gokarts brake?
I'm looking at some road car and yard karts that are one wheel drive. They have a band brake for that same one driv wheel. How well do these brake? Do they pull to one side when braking?
Thank you
Old 10-22-2019, 09:04 PM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
Quote:
Thank you
Better than, no brakes
Nope
& they don't "pull to one side" when accelerating either
RESISTANCE IS FUTILE
The Following User Says Thank You to Functional Artist For This Useful Post:
Bmr4Karts (10-22-2019)
Old 10-22-2019, 09:14 PM
With my Adult Razor Dune Kart I tried one wheel drive by removing one wheel key. My attempt was to help with the turning radius but it was terrifying. Pulled to one side wheel accelerating and was very unstable braking. Maybe it was due to the extremely short wheelbase.
Old 10-22-2019, 09:38 PM
e-Lemon-aid was/is a 1-wheel peel kart
http://www.diygokarts.com/vb/showthread.php?t=37442
I tried several motors on 'er & she never "pulled to one side"
...even with a 48V 1,000W MY-1020 or a 1,800W Boma motor
Old 10-23-2019, 08:04 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
I don't think you've driven my torque monster Starbird, Kevin.
It will violently torque steer to the right if I let it.
As far as brakes, I have no experience with the single band brake system, I have scrub brakes(which I'm honestly pretty satisfied with). It's fairly safe to assume a single band brake would be better than scrub brakes, though.
Currently Flathead-Crazed
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Bmr4Karts (10-23-2019)
Old 10-23-2019, 08:32 AM
jpenn82 jpenn82 is offline
I have 3 karts with the band brake setup and they stop fine. They are live axel though
  #7
Old 10-23-2019, 08:42 AM
Your probably right about the short wheelbase
Now that I remember, the !Arriba kart pulls to one side
...depending on the throttle that's activated
*you can almost steer with just with the throttles
Here is an old video of my daughter ridin' 'er
...with just (1) motor installed
---------- Post added at 07:42 AM ---------- Previous post was at 07:40 AM ----------
As far as brakes, I have no experience with the single band brake system, I have scrub brakes(which I'm honestly pretty satisfied with). It's fairly sake to assume a single band brake would be better than scrub brakes, though.
Can your "torque monster do this?
  #8
Old 10-23-2019, 08:47 AM
Quote:
I'm sorry, that has nothing to do with my question. lol
---------- Post added at 09:47 AM ---------- Previous post was at 09:42 AM ----------
Hey FA
If Arriba was a live axle kart, I bet it would wheelie even better with a single BLDC setup.
  #9
Old 10-23-2019, 09:18 AM
[/COLOR]Hey FA
I'm not sure if I would agree
...these 48V 1,000W MY-1020 (brushed) motors are little "BEASTS"
...they have massive amounts of torque coming out of that little 10mm shaft
  #10
Old 10-23-2019, 09:20 AM
You're right, I forgot that I modified my 48v controller to put out more amps. My 48v bldc is around 2800 watts.
  #11
Old 10-23-2019, 10:32 AM
Smerft85 Smerft85 is offline
Thank you
Click image for larger version
This kart is what I set up for my kids, it's a dead axle, and has the single band brake attached to the drive wheel. Single wheel powers and stops the kart, and I believe it to be a close representative of your question.
It has a 4hp subaru, and standard yard kart features, geared too high still, but better than before at 5.7:1. It doesn't torque steer, and I only notice it pull to one side in braking if you lock up the tire at top speed ranges, which are over 30mph for this kart at the moment according to a speed recording app on my phone. For normal trail riding and conservative driving it does fine with the single wheel set-up, and unless you are going fairly "wild" with engine and gearing, a kids yard kart should be just fine. Hope I helped with your question!
The Following 2 Users Say Thank You to Smerft85 For This Useful Post:
Bmr4Karts (10-23-2019), Functional Artist (10-23-2019)
  #12
Old 10-28-2019, 01:58 AM
landuse's Avatar
landuse landuse is offline
If the braking system is set up right, you will be locking up your tyres
  #13
Old 10-28-2019, 06:26 AM
Quote:
You mean the one tire, but that wasn't my concern.
I guess I wasn't clear with my question though. What I was concerned about is the vehicle tracking straight and slowing down at a good rate with only one wheel doing the work. I've received a helpful response and am willing to buy a kart with one wheel braking if I see a good deal.
Thank you
The Following User Says Thank You to Bmr4Karts For This Useful Post:
Smerft85 (10-28-2019)
  #14
Old 10-28-2019, 07:25 AM
landuse's Avatar
Thank you
I have never personally owned a one wheel peel kart, so I cannot speak from experience, but I haven't heard anyone on the forum ever negatively speak about not tracking straight due to one wheel being braked (or when accelerating hard).
I think you will do just fine if you buy one
  #15
Old 10-28-2019, 08:09 AM
Teehee....
I'm that one weirdo whose kart doesn't want to track straight...
Granted though my axle is bent, and the steering leaves something to be desired.
OP - If it was good enough for companies like Manco to use it, I'd say it's fine.
Git on that kart and RIDE IT!
  #16
Old 10-28-2019, 08:48 AM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
I do have a Manco that torque steers a little, but it has 9:1 gearing and a predator 212 almost stage one (po removed exhause and re-tuned so it has a straight pipe). Although it likes to twist the backplate on acceleration. But if you are giving it gas and then let off, it'll start turning left.
For his personal safety, keep this one away from bicycles.
  #17
Old 10-29-2019, 10:41 AM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Hey, one wheel gokarts are called mini-bikes.
I do not recall Congressman.
  #18
Old 10-29-2019, 11:03 AM
Or is a 1WD go kart a 4 wheeled minibike??? Hmmmmmmmmm.........................
Philosophy with Poboy.
  #19
Old 10-29-2019, 06:43 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Teehee....
The plot thickens.
Your kart's geometry is askew--that'll do it. Bad steering will do it too....different tire pressures, bad bearings, I bet the list is nearly endless.
  #20
Old 10-30-2019, 07:53 AM
HOW DID YOU KNOW!!!
Ssshhhhh! Don't tell the world my drift setup!
Reply
