Reply
Old 08-26-2019, 07:33 PM
shewannameetkarty shewannameetkarty is offline
Default 212 can't get c clip off governor
I literally can't get the c clip off the governor tried flathead screwdrivers, pliers, everything, how do I get the **** thing out?
Old 08-26-2019, 07:50 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Maybe try cutting through it with wire cutters???
Currently Flathead-Crazed
Old 08-26-2019, 07:55 PM
karl's Avatar
karl karl is offline
Straight pick, position opposite of open end,between clip and shaft, tap end of pick until clip deforms and falls off
Old 08-26-2019, 11:47 PM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
I hate messing with that thing! I prefer to take the recoil housing and flywheel off... Then with a punch the whole gear and rod come out.
https://www.youtube.com/user/dirtyinaz
The Following 2 Users Say Thank You to 2SlickNick For This Useful Post:
bob58o (08-30-2019), Flyinhillbilly (08-27-2019)
Old 08-27-2019, 02:57 AM
Just like Karl said. I also use a pick aka awl. It’s the best I have found to get the clip out.
Old 08-27-2019, 07:39 PM
Munk Munk is offline
Junior Member
I had the same issue: http://www.diygokarts.com/vb/showpos...8&postcount=27
I wasn't able to get it off with just the flathead, and even tried dremelling the clip off with a needle tip, as well as simply breaking apart the governor wheel into pieces until it was just, well, gone! Neither approach worked so spare yourself the grief. I had extra difficulties because I left the motor in place on the go kart (no unmounting, so a whole bunch of other things like the frame of the kart etc. complicated the removal even more).
Here is what I did. I used the flathead to try to open that existing gap as much as I could, but after a long time only was able to widen it a tiny fraction. I then used the same flathead to try to move the clip away from the gear just a little, by using the corner of the flathead tip in various twisting/prying motions. It was slow going, but once I stopped trying to 'get it done' I slowed down and made progress. I was able to slide that clip away from the gear maybe a 1/16 of an inch, but that was just enough for me to get the tip of my vice grips to bite down on it, and from there I just slid it the rest of the way off.
I don't think this method will work with pliers alone, or without first creating a tiny gap between the clip and nylon gear for the vice grips to be able to grab just the clip (and not the clip plus gear)
Does that make sense?
  #7
Old 08-27-2019, 09:06 PM
Flyinhillbilly's Avatar
Flyinhillbilly Flyinhillbilly is online now
The great cornholio
Quote:
Thatís how I do it too. Itís much easier that trying to dig the clip out.
You can't drink all day if you don't start in the morning
The Following 2 Users Say Thank You to Flyinhillbilly For This Useful Post:
2SlickNick (08-28-2019), bob58o (08-30-2019)
  #8
Old 08-30-2019, 12:27 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Remove flywheel. Punch the shaft out of the block. Use a bolt to plug the hole. I think I tried 1/4-20 first, but ended up tapping for a 5/16” bolt.
The Following 2 Users Say Thank You to bob58o For This Useful Post:
2SlickNick (08-30-2019), Flyinhillbilly (08-30-2019)
  #9
Old 08-30-2019, 09:14 AM
The great cornholio
Quote:
Originally Posted by bob58o View Post
Remove flywheel. Punch the shaft out of the block. Use a bolt to plug the hole. I think I tried 1/4-20 first, but ended up tapping for a 5/16Ē bolt.
I put the shaft back in with a dab of locktite.
The Following User Says Thank You to Flyinhillbilly For This Useful Post:
bob58o (08-30-2019)
Reply
