Old 05-16-2017, 09:52 AM
Functional Artist's Avatar
Default El Dingo Modifications & Upgrades
I have had tunnel vision lately, workin' on other projects.
The Kart itch is comin' back.
So I have been thinkin' about what can be done to squeeze MORE out of El Dingo.
She moves right along but, I was expecting more.
There seem to be three options:
adjusting the gear ratio. (now @ 5.4:1 maybe try 3:1)
higher voltage. (more batteries now @ 36v maybe try 48v)
or lighter battery pack. (lithium ion)
Hey Sid,
what do you think about the specs on this battery pack?
http://www.ebay.com/itm/36V-20AH-LiF...3D192188409628
It's 36v, has a built in BMS, comes with charger & under $400.00.
The drawback is it's only 20 Ah, where my battery pack now is 35Ah but, the difference in weight should make up for some of that.
Old 05-16-2017, 12:54 PM
Kartorbust's Avatar
This guy used Chevy Volt modules for his dirt bike build.
http://www.minibuggy.net/forum/proje...ike-build.html
Functional Artist (05-17-2017)
Old 05-19-2017, 08:57 AM
Mr. Spindle's Avatar
Mr. Spindle Mr. Spindle is offline
Time to start digging in cars and other junk for electric stuff, lol, I'd rather gas...
I just bought a honda!
Old 05-19-2017, 09:06 AM
Kartorbust's Avatar
The beauty of electric motors is, instant torque at 0 RPM. Rather than spinning up to 2500, it's as soon as you hit the go pedal. I still like gas and oil burners, but do I ever hate having to buy gas on a constant basis. Though charging batteries is equally as bad and takes longer. R/C drivers have done this for years, used to be nitromethane was the way to go, despite sucking to retune every run. I mean nitro engines had the longer run times vs electric R/Cs, and they still kind of do since you can refill the tank faster than charging a battery, but if you have a second battery it's a crapshoot as far as swapping out goes vs filling up.
If electric motors and control modules were not so expensive and a decently light battery setup didn't cost your first born, it would be the way to go. Less maintenance over gas engines, plus more power, relatively speaking.
Functional Artist (05-19-2017)
Old 05-21-2017, 10:59 AM
Hey Sid,
Well, after more research NO this bat pack is NOT a good fit.
The motor on ElDingo will draw well over 100A.
The specs on the above mentioned bat pack are:
-Instantaneous maximum discharge current: ≤30A
-Over discharge protection current:≤45A
& the Chevy Volt modules specs are:
-Continuous current 240A
-Peak current 350A
The Volt modules only seem to come in multiples of 24V.
...still looking for 36V bat pack possibilities.
...maybe have to step up to 48V
Old 05-21-2017, 08:25 PM
Kartorbust's Avatar
I have no idea of its possible, but could the modules be wired in a series to get to 48v or is that not possible?
Old 05-27-2017, 11:01 AM
Yes, it's possible.
I was just trying to stick with 36V because that's how the kart is set up. (right now)
Still looking.
