  #21
Old 08-25-2010, 03:33 AM
fowler's Avatar
fowler fowler is offline
r97 that is certanly a buggy worth looking into the power would be imense
imagine a motorcycle ****le engine
modelengineer i never knew what I\C stood for but yeah it is
That's not an oil leak
It's horsepower sweat
  #22
Old 08-25-2010, 10:59 AM
r97's Avatar
r97 r97 is offline
Measure twice cut once
rotary engines are not only considered i/c but there also 4-stroke, its basically piston engine vs jumbo triangle, lol
  #23
Old 08-26-2010, 07:15 AM
sideways's Avatar
sideways sideways is offline
Unfinished projects king.
They are not 4 strokes as they do not "stroke". They go round and round not up and down. The output shaft also turns 3 times for every revolution of the rotor and the the rotor has three sides so it fires once every revolution. That's like a 2 stroke, not a 4 stroke. It's still not either of those though.
Hayden
  #24
Old 08-26-2010, 07:19 AM
fowler's Avatar
if anything its either a 3 stroke cause each side fires once each revolution or its a 1 stroke cause at every stage there is a side fireing
it depends if u compare it to a 1 cylender or a 3 cylender
  #25
Old 08-26-2010, 07:54 AM
modelengineer modelengineer is offline
Lord of the noise
I don't think it's possible to classify a rotary as a type of "stroke". The rotor doesn't stroke up and down like a piston. If anything it's a 2-stroke as it fires every revolution of the output shaft, the same as a 2-stroke piston engine. If you're taking it as revolutions of the rotor then it fires 3 times every revolution, making it a 2/3rd stroke engine.
In other words, I completely agree with what Hayden said
Andrew
GS500F powered...
  #26
Old 08-26-2010, 07:56 AM
r97's Avatar
r97 r97 is offline
dang, more websites lying to me, i hate it when this happens
  #27
Old 08-26-2010, 08:21 AM
fowler's Avatar
yes i guess so
but yeah it really fits into its own area
  #28
Old 08-26-2010, 09:08 AM
r97's Avatar
r97 r97 is offline
this website says its 4-stroke, http://www.freedom-motors.com/index....d=97&Itemid=77
  #29
Old 08-26-2010, 09:14 AM
fowler's Avatar
noobs
their engines are not even being produced yet
  #30
Old 08-26-2010, 11:14 AM
redsox985's Avatar
redsox985 redsox985 is offline
They make some pretty big claims there too. 18hp out of a 150cc motor. I think they're basing 4 stroke off of the fact that it runs on gasoline not mix. If they were to say it's a 2/3rd stroke like posted above, this forum would be the only google result simply because modelengineer just conceived the idea.
  #31
Old 08-26-2010, 12:53 PM
Rotore Rotore is offline
Teh SPIK
those engines are in the $2k-3k range eeeeeeeeeeeehh
modelengineer idk dude but yes i think it has to do with it not being a piston engine.
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
  #32
Old 08-26-2010, 04:13 PM
KieranM's Avatar
KieranM KieranM is offline
Doin It!!
yep as redsox said, they only say 4 stroke because its not a mix, the could also say 6 stroke but lets not go there hahaha ( just by it using straight petrol/gas obviously)
  #33
Old 08-26-2010, 05:06 PM
Teh SPIK
It'd be kinda cool to hace one of those sachs 303's
  #34
Old 08-26-2010, 05:19 PM
r97's Avatar
r97 r97 is offline
i read some where people put oil in the gas sometimes because the oil ends-up in the same place as the gas(maybe i got lied to again, lol)
  #35
Old 08-26-2010, 07:43 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Real serious people reroute their injection pump to run on a bottle of 2 stroke oil instead of 4 stroke oil(which isn't really made to burn). It still needs 4 stoke oil in circulation for bearings and whatnot.
  #36
Old 08-26-2010, 07:50 PM
r97's Avatar
r97 r97 is offline
ha! i wasn't lied to! (this time, lol)
  #37
Old 08-26-2010, 07:52 PM
Doc Sprocket's Avatar
These 2-3-4 "Stroke" debates might be more clear if we use the word "cycle" Let's face it, nothing's "stroking" here, but there IS a cycle...
As for the oil mix thing- I never knew that. So do all those millions of Mazdas have an oil tank like a sled that has to be refilled on a regular basis? What sort of oil was (is) required?
EDIT- I just did a bunch of searching, it is indeed by definition a "Four Cycle" engine. Havent found anything on the oil yet...
  #38
Old 08-26-2010, 08:05 PM
Lord of the noise
The mazda's burn the engine oil. A little pump pumps it into the inlet as it runs. You have to top up with oil occassionally. Lots of people, as said above, get rid of the little oil pump and run pre-mix 2-stroke oil.
Andrew
GS500F powered...
  #39
Old 08-26-2010, 08:14 PM
So- What? It feeds from the crankcase? That's kind of a weird arrangement... Wonder what that does to the whole oil change interval thing... Come to think of it- Emissions tests? Ouch!
  #40
Old 08-26-2010, 09:15 PM
r97's Avatar
r97 r97 is offline
wouldn't a rotary not have a crank case? and its not a weird arrangement just the best way of getting oil to the components. i'm not completely sure but don't rotary engines score better on emission testing , i don't think they go through oil horribly fast though, i'm not completely sure, this is a new topic for me!
