Old 08-22-2010, 07:29 PM
Racerin Racerin is offline
Default ****el
Its me again with my crazy ideas. Anyway, has any1 seen or use a rotary engine/****el engine in a go kart? i saw a video with it already.
Old 08-22-2010, 07:56 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
i havent heard of one on a kart but theres prob a reason they dont use them often. for any one who doesnt know what this is,
Old 08-22-2010, 08:12 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
They make little rotary engines for race karts. smaller than a 5hp briggs, and rated for around 50hp. However they also cost quite a bit.
http://www.race-sport.net/aixro-xr-50-****el-specs/
If your looking to use a rotary engine, try to find an old arctic cat panther ****el snowmobile. they were made in the early 70s for a few years, 303cc 23hp or so IIRC, not amazing but its a start.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
Old 08-22-2010, 09:38 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Not worth the time, effort, $$$$$$$$$$$, etc. there are better options.
Old 08-22-2010, 09:50 PM
BoostCreepr BoostCreepr is offline
****els have a tendancy to blow for no real reason.. apex seals are a *****.. stick with a 3/4 wheeler motor with reverse!!
Old 08-22-2010, 09:52 PM
r97's Avatar
r97 r97 is offline
id love to take that engine into a mower shop and see how confused they get, lol
Old 08-22-2010, 11:10 PM
Rotore Rotore is offline
Teh SPIK
****els aré awsome a sachs 303 with a bridge port would be awsome
"No one is going to open doors for you your whole life, sometimes you have to open the dor yourself." Eddy
Old 08-23-2010, 12:26 AM
sideways's Avatar
sideways sideways is offline
Unfinished projects king.
Only when idiots don't treat them right..... A properly treated rotary is as reliable as any other engine. People generally treat them like a 4 stroke, it's a completely different thing. They need to be properly warmed up before you rev them, you let them idle for 3-10 mins before driving them otherwise you will have problems. Many people also put the wrong oils in them and neglect checking the level, they burn oil like a 2 stroke, they need the right oil too.
They only got that reputation because people treated them wrong, now that basically all rotaries are owned by enthusiasts (and are mostly treated right) you never really hear of them blowing up.
/rant
Thanks
Hayden
Old 08-23-2010, 07:17 PM
/rant
Thanks
Hayden
i have owned over 13 FC3S' 7's i know my fair share about the ****le. you can beat them to death and rev the **** out of them and they still keep going but i have had a couple blow seals on me just trying to find a parking spot. it all depends on what u get from the previous owner, if it was broke in correctly. Alot of my buddys remove their oil lines and just add it to the fuel like a 2stroke. Either way to much of a pain to add to a cart i think.
Old 08-23-2010, 09:07 PM
Teh SPIK
Yes but most rotary engines can out rev an I/C engine easily and rotary engines can be built up to be some scary as$ track cars easier then piston engines the only true reason I've found that they blow is not properly maintained or some idiot thought he could tune it like any other engine. ****els are sensitive to tuning if not done right but if it's done correctly and has proper maintenance it'll last a long time. Take it from a puerto rican and an aussie we know our ****els...
  #11
Old 08-23-2010, 09:13 PM
mike75925's Avatar
mike75925 mike75925 is offline
thinker and tinkerer
i have heard that mecedes benz uses small ****els powered by co2 for seat belt tensioners. i wonder if anyone has been chopped in half?
deo non fortuna
  #12
Old 08-23-2010, 09:19 PM
Teh SPIK
That's different mike
  #13
Old 08-24-2010, 01:52 AM
fowler's Avatar
fowler fowler is offline
the mazda rx 8 uses them dont they
they are a pretty good car that fairly shifts
That's not an oil leak
It's horsepower sweat
  #14
Old 08-24-2010, 04:50 AM
KieranM's Avatar
KieranM KieranM is offline
Doin It!!
yep
  #15
Old 08-24-2010, 02:06 PM
Teh SPIK
Mazda got everything right with the rx8 when it comes to styling and handling but the engine is poop that's stock it can be improved but swapping it out for a true 13b or 20b is the way to go.
  #16
Old 08-24-2010, 03:43 PM
Nbaker Nbaker is offline
i want some of these engines so bad
  #17
Old 08-24-2010, 05:14 PM
modelengineer modelengineer is offline
Lord of the noise
rotary = I/C engine
I think it's a great idea. If only we had these small rotaries in Australia... and they were cheap
Andrew
GS500F powered...
  #18
Old 08-24-2010, 11:00 PM
Teh SPIK
Originally Posted by modelengineer View Post
rotary = I/C engine
eeeeeeeaaaaaaaaaaahhhhhhh most people dont consider a rotary a conventinal I/C engine
  #19
Old 08-24-2010, 11:18 PM
r97's Avatar
r97 r97 is offline
holy crap guys check this out! http://www.freedom-motors.com/index....d=75&Itemid=68 if we can get these cheap they would be perfect, we could make stuff like 20hp mini bikes easily!
  #20
Old 08-25-2010, 12:08 AM
Lord of the noise
I/C = internal combustion. How is a ****el not an I/C engine? Most people, I would hope, would say a ****el is not a piston engine, rather than saying its not internal combustion engine.
That rotapower thing looks pretty awesome, but I'd imagine they are a bit on the expensive side.
Andrew
GS500F powered...
