Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
Closed Thread
Old 07-12-2008, 08:29 PM
ElectricalBen ElectricalBen is offline
Default i seen some weedeater things so i thought id post what i did with one
a 32cc i think weedeater brand all painted up weedeater
peaople doubted me that it would run but i worked my arse off and got it running. max speed was 45 down hill had to pedal to about 5 mph and push my homemade clutch in and it start up then pedal assist till about 10 and see ran average 35 needed pedal assist up huge hills but normal hills slowed up to about 20 so i was impressed
Old 07-12-2008, 09:41 PM
oscaryu1 oscaryu1 is offline
That engine's offa a weedeater?!
Nice exhaust!
Old 07-12-2008, 10:05 PM
2or3wheels 2or3wheels is offline
sweet, i want to use a chain saw from back in the day for a project like this, no emmisions then and they make alot of HP for the CC's. Could you take more close up pics of how you mounded the engine and the drive set up?
BTW sweet ram intake and chrome exhaust.
Old 07-13-2008, 09:14 AM
no because after about 200 miles of driving the engine shaft broke off sice it was so small. but all the pullys were homemade. the engine mounting i got 2 real long bolts and a 2 little pieces of metal on the top i got a long piece of metal and bent it to the profile of the engine ran the bolts down through it then the 2 little pieces were bolted down on the block of the engine, then welded to the bolts that were coming down so i could bolt it down from the front. then the back of the engine i used that plate and notched it then bolted it down.. if that makes any sense
Old 07-13-2008, 10:47 PM
well weld it on hehehehe.
Closed Thread
