Old 04-12-2018, 09:05 PM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
Default Speedway Scarab
Since I created a Facebook page called " American Minibikes " I figured I should own an American-made minibike. I will add to this thread as I make progress.
It stinks that somebody cut part of the motor mount plate, because they also cut the hole for a jack shaft bearings. not sure if I will weld a new bracket there for the jack shaft, or try to use a torque converter like the previous owner did.
I can't believe I did a rookie mistake and did not turn my phone. Oh well more sideways pictures so I can blend in with the rookies.
https://www.youtube.com/user/dirtyinaz
The Following 5 Users Say Thank You to 2SlickNick For This Useful Post:
bob58o (04-12-2018), Desertduler (04-13-2018), ezcome-ezgo (04-13-2018), itsid (06-20-2018), landuse (04-13-2018)
Old 05-14-2018, 01:11 AM
2SlickNick's Avatar
I cut a jackshaft bracket out of 1/4" plate, drilled a 1-3/8" hole, and my buddy TIG welded it in place. I basically used the other side as a guide, traced then shape until I was ready to weld.
Simple fix. I have also in a little time with wire wheel.
It's basically just getting it ready for paint, everything appears as it should be. Even tires are in good shape.
I will probably have to use a 20 series torque converter. In meantime I will use the clutch and jack shaft set up. Or I may keep it... As I do like jack shafts for built motors.
Old 05-14-2018, 01:13 AM
2SlickNick's Avatar
Here are the numbers I am thinking about running currently. But still a lot of work to do to get to that point. Just playing with the gear ratio calculator.
KartInfo by kartcalc.net:
Code:
KART
Kartname : Speedway Cc JS RW diameter : 16 in Weight : 300 lbs
ENGINE
Engine type : Pred HP : 6.5 Torque : 12.86 Nm | 9.48 ftlb RPM : 5600 Governor removed : true Assummed HP : 7.18
TRANSMISSION
System : Clutch & Jackshaft Clutch sprocket : 10 Jackshaft in : 17 Jackshaft out : 12 Axle sprocket : 50 Final Ratio : 7.08:1
PERFORMANCE
Wheel Torque : 91.05 Nm | 67.15 ftlb Acceleration : 3.29 m/s≤ | 10.79 fps≤ Top Speed : 60.59 km/h | 37.65 mph
Old 06-20-2018, 08:38 PM
2SlickNick's Avatar
I met a new friend that makes seats. The sides are a shiny sparkly cream color, and the top is black with gold and silver sparkly stuff.
Tires arrived, used my paint pen to color in the lettering. 20 series in-board driven unit arrived.
Just sent the frame and all the parts off to get painted.
Going with a black frame with gold flake, black and gold rims, and I'll have the handlebars and forks painted and a shiny silver.
The Following User Says Thank You to 2SlickNick For This Useful Post:
bob58o (06-20-2018)
Old 06-20-2018, 08:49 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Sorry for the interruption. Do you still got those 212%er patches?
Old 06-20-2018, 08:53 PM
2SlickNick's Avatar
I do. Message me for details.
bob58o (06-20-2018)
Old 07-15-2018, 06:43 PM
2SlickNick's Avatar
Some progress.
The Following 2 Users Say Thank You to 2SlickNick For This Useful Post:
bob58o (09-19-2018), ezcome-ezgo (07-16-2018)
Old 07-15-2018, 07:40 PM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
Ha ! I didn’t know that was your page. Now go approve me. Lol
Old 09-14-2018, 06:31 PM
2SlickNick's Avatar
And done...
andrecht (09-15-2018), bob58o (09-19-2018)
Old 09-15-2018, 04:31 PM
supermanotorious's Avatar
supermanotorious supermanotorious is offline
Winchmaster 5000
sweet stache
www.phoenixwinch.com
www.facebook.com/wakeskatewinches www.youtube.com/user/phoenixwinch
  #11
Old 09-15-2018, 07:20 PM
2SlickNick's Avatar
Originally Posted by supermanotorious View Post
sweet stache
Bahaha!
  #12
Old 09-17-2018, 12:24 AM
landuse's Avatar
landuse landuse is offline
Looks awesome Nick
  #13
Old 09-18-2018, 09:54 PM
2SlickNick's Avatar
Originally Posted by Joe-405 View Post
Ha ! I didnít know that was your page. Now go approve me. Lol
Bahaha thanks... Will do.
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
Originally Posted by landuse View Post
Looks awesome Nick
Thanks - I definitely like have some vintage toys.
---------- Post added at 08:54 PM ---------- Previous post was at 08:54 PM ----------
sweet stache
Working on it - LOL!
  #14
Old 09-19-2018, 03:14 AM
bob58o's Avatar
Are you going to keep the clutch or swap in the TC?
Stache should be in full swing come Movember. lol
  #15
Old 09-19-2018, 10:38 AM
2SlickNick's Avatar
I can't use the TC unless I get/find an original Salsbury TC which is about 5.5" driven unit. A 6" driven 20 series rubs on the rear swing arm. I may put in a mild engine build with the black mamba jr camshaft. I am actually a fan of the JSwith modified engines and fan of TCs with stockers.
A little wax will help the stache come November LOL
bob58o (09-19-2018)
