Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Closed Thread
Old 11-07-2018, 06:47 AM
Jo.qc Jo.qc is offline
Junior Member
Default 1000W electric kart build for kids and grown up
Here's the electric go kart i designed and build last summer. I've design it to be ajustable (pedals, steering and speed) for kids and grown up to be able to drive it and have fun. It's 36v and 1000w. It got a 30km/h top speed and a 40min ride time.
You can check the build video with the part list in the description
And the finish product and riding video
The Following 3 Users Say Thank You to Jo.qc For This Useful Post:
ezcome-ezgo (11-07-2018), Functional Artist (11-07-2018), itsid (12-27-2018)
Old 11-07-2018, 09:46 AM
ezcome-ezgo's Avatar
An epic build! The attention to detail is inspiring. Great job!
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
Jo.qc (11-07-2018)
Old 11-07-2018, 11:43 AM
Tpdingo Tpdingo is offline
Quote:
Great job? No no no.
That's an absolutely marvelous work of art and craftsmanship os you have there.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
The Following User Says Thank You to Tpdingo For This Useful Post:
Jo.qc (11-07-2018)
Old 11-07-2018, 02:10 PM
KartFab's Avatar
KartFab KartFab is offline
looks good! But did you really build it for your daughter? haha
Free Go Kart Plans https://kartfab.com Go Kart Videos https://www.youtube.com/c/KartFab
Old 11-07-2018, 02:29 PM
Junior Member
I would'nt have built it if it was for myself only. But yes I also had fun designing, building and driving it.
The Following User Says Thank You to Jo.qc For This Useful Post:
KartFab (11-09-2018)
Old 11-08-2018, 12:04 AM
landuse's Avatar
landuse landuse is offline
Nice one!!!
The Following User Says Thank You to landuse For This Useful Post:
Jo.qc (12-28-2018)
  #7
Old 12-26-2018, 03:52 PM
sikbrik sikbrik is offline
Just found time to watch this and wanted to say what a great job you did! Clean build with really nicely engineered adjustability. Well done!
The Following User Says Thank You to sikbrik For This Useful Post:
Jo.qc (12-28-2018)
  #8
Old 12-27-2018, 03:00 AM
itsid's Avatar
itsid itsid is offline
Very nice..
the axle appears to be on the flimsy side for my taste (especially with the large stick out)
but still.. looks very well made
Jo.qc (12-28-2018)
  #9
Old 12-28-2018, 06:25 PM
Junior Member
Thanks guy! The axle is 3/4" diameter and it does'nt seem to flex even with higher weight people on it. There is about 4in between the bearing and the wheel. I can bring the wheel closer to the bearing if it became a issue.
Today I modified the steering geometry a bit because my ackermann angle wasn't as I wanted it to be. I had to bring out the tie rod end point on the hub. It turn really better now. It was already good but now it's even better. I need to make better looking brakets and longer tie rod now.
I also changed the sprocket from a 60tooth to a 72tooth for more torque.
And I finaly got a can of wheel paint and painted the rear wheels
  #10
Old 12-28-2018, 07:50 PM
itsid's Avatar
it's the "bump in the road" that causes issues with axles like these..
Personally I'll upgrade to a 1" axle once the kids grow older (and heavier) and the kart get's set up for higher speeds (more significant impact on bumps )
but as soon as it's bent you'll surely fix that anyways,
so no need to think about it now I guess
It's quite obvious how much thought, love and effort you put into making this kart.
So I'm not too concerned about it being less than perfect.
I mean your steering was good,
but you improved it to be as good as possible for no other reason
than you knew there was still room for improvement...
that says alot, doesn't it
Jo.qc (12-29-2018)
  #11
Old 01-08-2019, 05:57 PM
Junior Member
I finaly came with a design I like for the fenders. What do you think?
  #12
Old 01-08-2019, 07:52 PM
itsid's Avatar
I liked it better w/o fenders tbh.
and while fenders do serve a legit purpose..
too little of a gap and they are constantly filled with wet leaves and mud,
in fact you'll always find the perfect size stick or stone on the road to get
wedged under the fender unless you'll have them comically far from the tyre.
There's a good reason you don't see too many 'road karts' with fenders
But yes, to answer your question.. IF you really want some,
those are looking good
  #13
Old 01-08-2019, 08:19 PM
Junior Member
Thanks for your comment! I think I will put a little bit more clearence. The main purpuse of them is more to protect the driver. The kids who drove it so far have put their feet on the front wheels a lot, so I wanted something to prevent that. I'm mostly driving it on dry asphalte and it would only be 8 bolt to remove to get them off if I need to. I think I'll give them a try and see if I like them.
  #14
Old 01-08-2019, 09:07 PM
Looks good! Did I miss what the construction materials will be?
  #15
Old 01-09-2019, 05:07 AM
Junior Member
16Ga steel
  #16
Old 01-09-2019, 06:54 AM
I like side pods.
Wow that really looked better on my screen.
  #17
Old 01-09-2019, 07:45 AM
itsid's Avatar
I like side pods.
uuugh... that looks awkward on MY screen
  #18
Old 01-09-2019, 06:45 PM
Junior Member
Thanks for your idea but I don't really like the side pods. It can't turn with the wheels as I want to.
Started on the fender fabrication today.
Quinc (01-10-2019)
  #19
Old 01-09-2019, 11:13 PM
landuse's Avatar
Looks good, but aren't they going to be heavy?
  #20
Old 01-10-2019, 08:13 AM
Junior Member
It's about 7 pounds for all the fenders.
landuse (01-10-2019)
Closed Thread
