  #221
Old 09-15-2019, 07:41 PM
Functional Artist's Avatar
Default Systems Check
To connect the throttle cable to the thumb throttle, I simply drilled a hole, ran the cable thru it & used a "wire nut" as a "stop" to come in contact with &/or "trigger" it, as the cable travels
Seems to work quite nicely
Then, I did a quick check to make sure everything is functioning properly.
Made a video of the "check" too
RESISTANCE IS FUTILE
  #222
Old 09-16-2019, 07:20 AM
Default RPM test
I set 'er up on blocks
...attached the RPM meter
...& then, did some "lightly loaded" RPM tests.
(just the drag of the chain, sprocket, axle & wheels)
  #223
Old 09-16-2019, 07:48 AM
Budget GoKart's Avatar
Aka a kenbar
If i ever find this for sale im putting a gas engine on. That is if you ever sell it
  #224
Old 09-16-2019, 08:26 AM
Well I don't think he'll ever sell it to you if you're just going to stick a gas engine on!
Don't change a thing Kevin!
Currently Flathead-Crazed
Functional Artist (09-16-2019)
  #225
Old 09-16-2019, 08:45 AM
Tpdingo Tpdingo is offline
Electric is the way to go....I don't think even the cheapest electric motor can compete with gas. Insta-torque through the whole RPM range! AND NO CLUTCH OR TORQUE CONVERTER!!
Hey FA, can you use one of these on your next project
https://www.walmart.com/ip/JEGS-3010...xoCncIQAvD_BwE
  #226
Old 09-16-2019, 11:28 AM
I haven't done MPH tests yet
But, this thing flies
Here is some first ride footage & loaded RPM test data
  #227
Old 09-16-2019, 11:31 AM
That's a whole lot of motor
...like for a car, not a kart (well maybe Joe 405's kart )
  #228
Old 09-18-2019, 07:37 AM
Well, the loaded RPM test wasn't very conclusive
...gonna have to do 'em again
The ride was really fun though
First, we gotta get the battery pack, charged back up
I bought a 60V 2.5A SLA battery charger, last fall (~$20.00)
https://www.ebay.com/itm/60V-20AH-Le....c100005.m1851
...but, it came with the 'dreaded" C-13 DC output plug
So, I cut 'er off
...double checked the "polarity"
…& soldered on an XT-60 plug
Then, I soldered the receptacle onto the charge wires, on the kart.
When she's charged back up, we'll get back to testin
  #229
Old 09-18-2019, 10:15 AM
andrecht's Avatar
andrecht andrecht is offline
Jup, picture = me
Just make sure you mark the polarity 🤣
  #230
Old 09-18-2019, 02:57 PM
High speed in reverse!
  #231
Old 09-18-2019, 07:32 PM
No, just front wheel drive.
  #232
Old 09-18-2019, 07:54 PM
While charging, I gave everything a quick "once over"
...Uum, Houston we have a problem
What's wrong with this pic?
...besides ugly welds
  #233
Old 09-18-2019, 08:08 PM
Tie rods sticking out like a red sore thumb? No end caps on frame tubing?
You know we're too lazy and/or unintelligent to play guessing games, Kevin.
  #234
Old 09-18-2019, 08:23 PM
Nope, none of those things warrant a "Houston we have a problem" designation
...gonna have ta look closer
Clue: a simple oversight, on my part
  #235
Old 09-18-2019, 11:25 PM
karte_m0lim's Avatar
karte_m0lim karte_m0lim is offline
forget to tight up king pin?
YouTube: https://www.youtube.com/user/kartem0lim/videos?
  #236
Old 09-19-2019, 05:16 AM
Aka a kenbar
Unpainted spindle brackets and the tie rods super close to the frame?
  #237
Old 09-19-2019, 06:05 AM
BINGO!
Winner, winner chicken dinner
Yup, total oversight on my part
I've put several miles on 'er
& kinda surprised the nuts are even still there
...but, I got 'em tight now.
  #238
Old 09-19-2019, 06:14 AM
Originally Posted by Functional Artist View Post
BINGO!
been there, done that
The Following User Says Thank You to karte_m0lim For This Useful Post:
Functional Artist (09-19-2019)
  #239
Old 09-24-2019, 08:08 AM
Default Testin';
I've been doin' some testin'
RPM test results
Low gear 330 (axle speed) x 5.4 (gear ratio) = ~1,780 RPM avg.
Med gear 620 (AS) x 5.4 (GR) = ~3,240 RPM avg.
High gear 950 (AS) x 5.4 (GR) = ~5,130 RPM avg.
Speed Tests
Top speed in low gear seemed to be ~11 MPH
Top speed in med gear looked to be ~24MPH
Top speed in high gear was 35MPH
There is more info & videos on these RPM tests in this thread
http://www.diygokarts.com/vb/showthr...t=41655&page=2
Here is the speed test video
...but, had some issues toward the end
* Sorry, the GPS screen didn't seem to record too well
...even with a zip tie
…& I kinda blocked 1/2 of the "ride along" part with my shoulder
  #240
Old 09-24-2019, 08:37 AM
Like I said somewhere else:
You need a GoPro!
Functional Artist (09-24-2019)
