Old 09-09-2019, 01:51 PM
shewannameetkarty shewannameetkarty is offline
Default Is it possible to use a torque converter on 1wd?
What the title says
Old 09-09-2019, 03:10 PM
Generally no.
It's very hard to get the chain alignment and clearances just right.
Currently Flathead-Crazed
Old 09-09-2019, 03:37 PM
Dingocat's Avatar
Dingocat Dingocat is online now
Broke
Is it possible? Yes. Is it worth it? No. You would have to move the engine sideways and probably up to fit it all. And then you would probably just spin the tire if you did get it to work.
Old 09-09-2019, 07:08 PM
anickode's Avatar
anickode anickode is online now
Unless you were building a reverse trike with a fat rear tire. Then, totally worth it. Otherwise, no.
"Well that would be a bomb."
Old 09-14-2019, 05:54 PM
jeffone jeffone is offline
Anything is possible
Old 09-15-2019, 02:02 PM
BigWes's Avatar
BigWes BigWes is offline
I bet you could leave a black mark on asphalt if you did though! But seriously, all you would do is smoke tires with it!
