  #41
Old 05-24-2019, 05:36 AM
LightningTeg's Avatar
Been getting alot of driving time. Kid loves it. Also I was able to rig up some TIG filler wire as an easy way to adjust choke from the drivers seat, and I replaced the rear shocks for the 3rd and final time. These are 13-3/4" shocks from gopower sports. The previous 12" had a good rebound and sprint rate but 12" was too short and the gas tank was smacking the rear frame on big bumps. Now we can fly around the property with no worries.
The Following User Says Thank You to LightningTeg For This Useful Post:
ezcome-ezgo (05-24-2019)
  #42
Old 05-25-2019, 07:09 PM
B.M.800's Avatar
B.M.800 B.M.800 is offline
TheBeal.
Originally Posted by LightningTeg View Post
1/2-20*
Its substantial now lol
Did I misread that? lol
Yeah, 1/2 sounds better.
Dean done this here thing to this here thing, y'all
  #43
Old 06-10-2019, 05:36 AM
Put a stage 1 kit on from gopowersports. Chopped up the exhaust pipe and then found a tractor muffler at the local tractor supply to help keep the volume reasonable. Took it for a quick spin the 15 minutes it was dry-ish Friday. Seems like it got a nice pickup in throttle response and overall power and the sound might be acceptable for the mrs! sounds good IMO. I will get a video soon.
  #44
Old 06-11-2019, 01:09 AM
landuse's Avatar
landuse landuse is offline
Nice!! Don't forget to brace that exhaust. It will snap off if you don't
  #45
Old 06-11-2019, 05:19 AM
Yeah I figured. Theres a threaded hole on the head casting from the old (intake?) that looks good.
  #46
Old 09-06-2019, 08:00 AM
So small updates
Been trying out different lubricants for the drive part of the torque converter (recommended dry spray moly, dry spray PTFE, and now white lithium grease). I've found the dry sprays dont do squat and maybe last one ride. First ride with the white lithium and it has been so smooth and much more enjoyable. I realize its not what is recommended but I dont care at this point if dust is going to accumulate. The dry stuff just wasnt working and I would literally have to tear it down every few drives to reapply.
Anyways,
Stage 1 kit on the kart has been nice (yes the muffler is braced hard to see it), really woke up the engine on the top end, and added a light in case any night riding is to be had. I really need to get some side mirrors on it so I can take it up the street and see what the top speed really is. Road is closed right now for construction so pretty safe at the moment.
Still have plans to add a basket to the back for storage, adding a better column to support the steering wheel shaft, and other small things.
  #47
Old 09-09-2019, 01:16 AM
landuse's Avatar
This is a sweet build!! Thanks for the updates
  #48
Old 10-23-2019, 10:24 PM
Kentguy13 Kentguy13 is offline
I like the brake caliper mount. Has it been working pretty good? Im about to add the same to my Grand Daddy. Any tips or tricks, or anything youd do different with that back brake?
  #49
Old 10-28-2019, 05:28 AM
Originally Posted by Kentguy13 View Post
I like the brake caliper mount. Has it been working pretty good? I’m about to add the same to my Grand Daddy. Any tips or tricks, or anything you’d do different with that back brake?
Yes no problems with braking system
Only tip I would give is to disconnect caliper from hydraulic system before bleeding. So bleed the hose first 100% then connect to caliper. It'll never get bled right otherwise.
They are good enough, but you might want to consider a mechanical parking brake for safe starting and storage.
Kentguy13 (10-28-2019)
  #50
Old 10-28-2019, 11:56 AM
Thanks for the tips. I happen to have a mechanical caliper laying around, I may just do that!
  #51
Old 10-28-2019, 06:08 PM
karl karl is offline
I see you have the driver clutch flipped around , hows it going? Any belt wear so far?
Clean build, looks great!
The Following User Says Thank You to karl For This Useful Post:
LightningTeg (01-16-2020)
  #52
Old 10-30-2019, 11:19 AM
Michal_Kamilka Michal_Kamilka is offline
Hello Guys
First of all, sorry for my not perfect English.
I have small question to you all.
Where I can get the building plans for Granddaddy go kart?
I tried with SpiderCarts website, but unfortunately I have some errors from the website (no any possibility to buy it directly from them)
Is there any other source from I can get it?
Maybe someone has pdf file and can share it?
Thanks for any answer. See you.
  #53
Old 10-31-2019, 12:50 AM
landuse's Avatar
Originally Posted by Michal_Kamilka View Post
Hello Guys
What problems are you having wit their website? Maybe email them directly and chat to them and see if there is any other way to get the plans?
  #54
Old 10-31-2019, 04:01 AM
After log in to Their website, and after pressing BUY NOW button I have info "your cart is empty".
I tried as well to contact directly with them by email but there is no any email address after pressing "Contact us" button.
I checked as well facebook profile, last post is from January 2015, so in my opinion this company can be already closed.
  #55
Old 01-16-2020, 05:15 AM
No issues really. My sister did break a belt when she was flogging it over the summer but that was before I had figured out the lubrication part of it (white lithium grease works best). So the driver was getting locked up under load and putting a ton of stress on the belt.
Sorry to hear that Im not sure whats going on
  #56
Old 03-21-2020, 08:54 AM
beny beny is offline
Hi friend, can you send me the map and details?
