Old 08-29-2019, 11:41 AM
shewannameetkarty shewannameetkarty is offline
Default Curious what would happen if I drilled a bunch of holes in the muffler
Pic related
Old 08-29-2019, 11:48 AM
anickode's Avatar
anickode anickode is offline
Your muffler would have holes in it and it would be noisy. And blow exhaust every which way.
"Well that would be a bomb."
Old 08-29-2019, 12:08 PM
^^THAT!
Swiss cheese mufflers don't work great I'm sure.
If you are wondering about easy performance gains without installing a header, just add a header.
Currently Flathead-Crazed
Old 08-29-2019, 12:24 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Give it a go.
Preferably, drill them all around the current exit hole; just some satellite holes around it.
If you're feeling adventurous after that, consider slicing the muffler open around the seam--I would love to see the inner chamber(s) and baffles.
Old 08-29-2019, 01:43 PM
txluke txluke is offline
I tried it once. I kept hearing metal shaving rattling inside that I couldn't get out. I just didn't want to put it on and have them fall down an open exhaust valve.
