Old 04-02-2019, 02:26 PM
txluke txluke is offline
Default Have you ever...
My kids pulled the top off of the air filter box and the kart sat out in a rain shower. Before I tried to crank it up I pulled the carb and gave it a good cleaning. Went to crank it up yesterday and nothing. I pulled for a good 5 min before I told the kids no riding for the day. Today I pulled the plug and saw there was no spark. I decided to just pull the motor and take it to my shop and dig into it. As soon as I set it on the workbench I saw that I had never turned the kill switch back to on.
Old 04-02-2019, 03:18 PM
Currently flathead-crazed
Like when you're looking for something and then, you realize it's in your hand!!
Your arm must hurt...
Local Bird Engineering Nut
Old 04-02-2019, 06:21 PM
Karttekk Karttekk is offline
Wow. Sorry to hear that. I did the same thing with my riding mower. Wouldn't crank or start, forget which one but I bought a new solenoid for it & it still wouldn't run. Ends up I forgot to lift the blade deck the last time I shut it off and the safety was on.
Old 04-02-2019, 06:25 PM
mckutzy mckutzy is online now
Ahhhh yes... almost threw out my shoulder forgetting that blasted switch....
Happens...
Old 04-02-2019, 06:59 PM
It gets even better when there is a kill switch on the engine and on the steering wheel. Flip the engine switch on then pull the rope 10 times only to realize the one on the steering wheel is off.
Old 04-02-2019, 07:45 PM
Flip switch on the motor... Momentary on the bars via the low oil relay, only one to forget then...
Old 04-03-2019, 01:16 AM
landuse's Avatar
landuse landuse is offline
I did something similar with my lawnmower.....but it turned out I had just run out of fuel!!!! It should have been the first thing I checked
Old 04-03-2019, 08:26 AM
J.S.@SMS J.S.@SMS is offline
Here 8am-? Mon-Fri
I once spent ten minutes trying to figure out why my minibike wouldn't start, only to then realize that I never put the spark plug boot back on.
And Karttekk:
My gokart did that once. And, being that it was a tecumseh, I thought that the carburetor took a dump again.
Old 04-03-2019, 09:26 AM
68kaiser 68kaiser is offline
I turn the fuel off after riding.. i remember about 150 feet down the road
