Closed Thread
Old 05-20-2007, 06:16 PM
gabinator92 gabinator92 is offline
Junior Member
Default 4hp briggs and straton
Hi i am a noob and I want to build a go-kart with my dad. I was wondering if a 4hp brigs and straton lawnmower engine would work and how fast it would go. Thank you and any advice or pointers would be appreciated.
Old 05-20-2007, 08:58 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
generally, a lawn mower engine won't work easily. Check http://www.diygokarts.com/engine/can...er-engine.html
Old 05-21-2007, 12:24 AM
my_mini_bike my_mini_bike is offline
is it a horizontal or vertical shaft?
Old 05-21-2007, 07:54 AM
Junior Member
vertical shaft
Old 05-22-2007, 12:24 AM
problem. you could do a crossed over belt, whats peoples experience with that? or look for a new motor
Old 05-22-2007, 07:47 AM
Junior Member
yah im looking for a new motor now. About how fast would be the fastest you could go in a 8hp one seater kart?
  #7
Old 05-22-2007, 10:45 AM
ed1380's Avatar
ed1380 ed1380 is offline
Banned
depends on teh gearing. you could have it do 200mph, but it would take forever to accelerate. or you could make it do 0-60 in 3 seconds, but it would never reach 60, but it will accelerate like haites.
it's a choice between acceleration and top speed
  #8
Old 05-22-2007, 01:16 PM
Junior Member
could you get a tranny or something ans shift gears so you can accelerate fast and achieve high speed??How much is it and would it be hard to install?
  #9
Old 05-22-2007, 04:46 PM
mikeandike mikeandike is offline
for whoever just read this i posted the wrong info. I just found it and its a forward/reverse gearbox with neutral and its 330$ theres no speeds on so its kinda useless. A torque converter has variable speeds on it. i think the ratios are 2.71:1 up to 0.90:1 overdrive. It's an infinity variable speed so the ratio will vary between the two ratios stated above depending on load and engine speed etc...
Closed Thread
