Closed Thread
Old 01-20-2014, 06:28 AM
gx390's Avatar
gx390 gx390 is offline
Junior Member
Default DIY Chain Tensioner
Hey guys, it's me again needing some more advice. So my go kart has a #35 chain, but it is too loose. But if I shorten it it gets too tight. I have considered shimming the engine, but I also switch between 72 and 60 tooth sprockets, so this won't work. (72 for bashing and 60 for speed). My next idea it to make a spring tensioner out of a spring, flat steel, and an idler gear, kind of like this picture. Will this prevent the chain from popping off?
Old 01-20-2014, 06:29 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
Yep......
Old 01-20-2014, 06:41 AM
landuse's Avatar
landuse landuse is offline
That is a slick tensioner. If you do something like that you will be fine
Old 01-20-2014, 07:46 AM
Poboy kartman Poboy kartman is offline
Banned
Since you didn't fill out your profile I don't know if there is one around you but. ......Tractor Supply should have an off-set link that may solve the problem. It basically eliminates 1/2 of a link.
Old 01-20-2014, 08:11 AM
anderkart's Avatar
anderkart anderkart is offline
This pic gives a better reference of where a chain tensioner should be located.
The Following 2 Users Say Thank You to anderkart For This Useful Post:
gx390 (01-20-2014), machinist@large (01-20-2014)
Old 01-20-2014, 12:52 PM
buckwheat buckwheat is offline
The overhung load on that bolt looks excessive. I would heat & bend a dogleg in the flatbar arm piece to reduce the overhung load. What kind of bearing is in the idler sprocket?
The Following User Says Thank You to buckwheat For This Useful Post:
gx390 (01-22-2014)
  #7
Old 01-20-2014, 05:20 PM
gx390's Avatar
Junior Member
Buckwheat, which picture are you talking about?
  #8
Old 01-20-2014, 07:00 PM
OzFab's Avatar
OzFab OzFab is offline
The pic you posted; a tensioner mech should be as close to the line of the chain as possible; the farther away from the chain, the longer the bolts you need & bolts tend to bend under load
The Following 3 Users Say Thank You to OzFab For This Useful Post:
Bmr4Karts (07-07-2019), gx390 (01-22-2014), machinist@large (01-20-2014)
  #9
Old 01-21-2014, 06:45 PM
Fabroman has said what I was thinking. The bolt needs to be shortened to reduce the over hung load. This will require moving the mounting bracket or re-engineering the arm and its pivot point. You might have to go to a larger sprocket so you can incorporate a ball bearing or at least a bronze oilite bushing.
The Following 2 Users Say Thank You to buckwheat For This Useful Post:
gx390 (01-22-2014), machinist@large (01-21-2014)
Closed Thread
