Closed Thread
  #21
Old 01-17-2014, 11:32 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
A traditional dead axle set up weighs less than all the stuff you got set up to MAKE a dead axle..... that solid axle pieces you have AND ALL the bearings weigh MORE than a tube with 2 bolts welded to the ends....... and be STRONGER/STRAIGHTER than youre idea of a diff.....
  #22
Old 01-17-2014, 03:21 PM
jandj's Avatar
jandj jandj is offline
Yep.
  #23
Old 01-17-2014, 03:37 PM
Poboy kartman Poboy kartman is offline
Banned
Exactly- and it gets worse. .... without knowing the parameters of the contest- this is the last place I would look for weight savings. Aluminum frame, live axle rims bored for either bushings or roller bearings on a dead axle turned down. Fiberglass and Kevlar wherever possible. Wheelbarrow tires........Aluminum fasteners. Aircraft paint. Graphite tubing... 2 cycle engine.
Need I go on.......
  #24
Old 01-17-2014, 06:32 PM
firemanjim's Avatar
and then we start swiss-cheese-N everything..... gotta shave them ounces.....
Closed Thread
