Closed Thread
Old 09-23-2013, 04:41 PM
dwayne mifflin dwayne mifflin is offline
08 crg road rebel 125yz
Default 08 crg road rebel engine mount foryz
ok i just landed this cart .i also got a 87 yz125 motor i need to buy or build a mount ,i have access to a welder . anyone know of plans or a cheep mount i can pick up ,im not worried about weight.
and can i use the rads off the yz bike that were with the engine on the kart. thanks again.
Old 09-24-2013, 06:52 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
There are a couple ways to mount that motor,easy and easier......
The easy way is to just fab up mounts with tube and plate. The EASIEST way is to cut the engine cradle out of the bike and weld it onto frame. Ill put up 3 pics as examples of what I have done, using both methods....
Yes you're going to use all the running gear from bike on kart. Rads,wires,ignition, ect.... but you will want to keep it all as close to what the mfg had it. Pump is only gonna pump so much so far. Dont put rad in front thinking MORE air..... too far for pump..... and you'll destroy the 125......
Old 09-24-2013, 06:58 AM
firemanjim's Avatar
The third pic is a honda atc engine cradle welded into my H3 hummer kart. The last pic is the motor and cradle from mini quad. I flipped the cradle,used theswingarm mount to make it adjustable. ... that one was too easy as was the H3 . Simple and straightforward. ...Hope that helps..... Got the shift linkage worked out too for a 2 seat and 1 seat kart if ya need help there too....
(Are the pics big enough now, or are they still tiny? Workin out bugs on my phone)
Old 09-25-2013, 05:12 PM
thanks .i haven't posted pics yet ,the kart i have dont want to weld anything on to ,the bike is gone so i don't have the cradle anymore . i bought some 2 inch square tube and angle iron today.i have a bit of a plan in my head . when i get done i will post picks .
thanks again for your feedback
Old 09-25-2013, 05:14 PM
ps the more im on this sight the more i want to build a miniture lav that would carry 6 paintballers. hmmm this could happen.
Old 09-25-2013, 06:18 PM
OzFab's Avatar
OzFab OzFab is offline
Quote:
Originally Posted by dwayne mifflin View Post
I bought some 2 inch square tube and angle iron today.
You'll also need some 1/4" x 1" flat stock...
I have a bit of a plan in my head
The easiest way is to cut 4 pieces of flat stock (2 for the front mount & 2 for the rear mount); when bolted to the engine mount holes, they should reach about 1-1.5" below the bottom of the engine.
Bolt those to the mounts & place the engine on a block of wood so it rests about 1" off the work surface. Place the angle on the work surface between the front & rear mounts (one each side), line everything up & weld.
There's your cradle...
  #7
Old 01-19-2014, 08:56 AM
Ok the mount is being welded as we Speak Once that's back I can start getting motor on frame , pump , clutch and shift linkage
Closed Thread
