Closed Thread
Old 02-25-2007, 08:48 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
Default steering problem -- too responsive
Have you guys had a steering setup that was just *too* repsonsive? I'm not a steering expert, so i'm unsure what I need to do to fix it, but every little bump has my steering wanting to get all squirrelly.
Old 02-25-2007, 11:51 PM
philip metzner philip metzner is offline
robert, i aint no expert either but if your arm on the stearing shaft is too long it will be too quick or sensitive, also if the arms on the spindles are too short, same thing. when it comes to the rest, like caster and camber and inclination, i realy dont know.-phil
Old 02-26-2007, 01:42 PM
Administrator
i think i figured it out and had the camber way off.
Old 03-06-2007, 07:10 PM
kart62 kart62 is offline
Junior Member
Check the wheel base, the shorter.....the quicker!
Old 03-06-2007, 09:56 PM
Administrator
good to see you back around kart62.
thanks everyone for the advice. I just moved but hopefully by the weekend I can finish my project on the bar stool. it's done, it's just scary b/c of the steering.
Old 03-09-2007, 04:48 PM
robert, you have to have some caster in there too, or it just wont track straight, and wonder all over the place, and also push the front wheels when trying to turn. you probably know more about this than me but i would guess at 3 degree's??? with the short wheel base i just dont know.-phil
Closed Thread
