  #41
Old 12-13-2012, 10:40 AM
Doc Sprocket's Avatar
Y'know, I coulda sworn I'd already stickied this in the Tools section, but yet, there is wasn't.
No matter- It's done now!
Well done, Tony! Perhaps shoot a vid of the whole dismount process?
The Following User Says Thank You to Doc Sprocket For This Useful Post:
OzFab (12-13-2012)
  #42
Old 12-13-2012, 10:53 AM
Nodroz's Avatar
Nodroz Nodroz is offline
Just wondering if this would work with big car wheel tires?
  #43
Old 12-13-2012, 06:13 PM
OzFab's Avatar
OzFab OzFab is offline
It's pretty simple really but ok. The problem is it takes two hands to remove so holding the camera becomes a problem
I wouldn't try it on this little thing. Before the motorised machines came along tyre fitters used similar rigs but, obviously, a lot bigger so, it is possible
  #44
Old 04-12-2013, 02:31 AM
Nodroz's Avatar
I am planning to build this in the weekend. Are you sure it works as good for a 5" rim? I need a tyre changer for my kart wheels.
I know you posted a video with a small tyre but not dissambly and assembly on the rim. Could you do the same for smaller or is it really exact the same thing as the bigger?
  #45
Old 04-17-2013, 10:32 AM
Nodroz's Avatar
Lets build this thing!
Sent from my GT-I8190 using Tapatalk 2
  #46
Old 04-18-2013, 12:44 AM
OzFab's Avatar
Sorry Alex, I missed your post.
As this was designed & built primarily for my kart rims (I now have two karts running on 5" rims) I can assure you it does work on them. The only difference is in the tyre lever when fitting tyres
  #47
Old 07-06-2013, 04:17 AM
Nodroz's Avatar
Can you get the movies back online, Fabroman? They appear to be gone on photobucket. :'(
  #48
Old 10-06-2013, 07:11 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
U da MAN......... (you're the man!)
  #49
Old 10-06-2013, 07:11 PM
OzFab's Avatar
Sorry Alex, vids back up now (only took 3 months...)
Yeah, I know Jim
  #50
Old 11-03-2013, 10:09 AM
Oxymoron's Avatar
Oxymoron Oxymoron is offline
Newbesque builder.
This is great. I got one of those small cheapo ones from HF... piece of junk. It does work, but it's cumbersome.
I'll definitely have to make one of these. Thanks for the write up Fabroman
Hi. I'm Chris.
  #51
Old 11-03-2013, 10:19 AM
OzFab's Avatar
No probs; let me know if you get stuck on anything...
