  #21
Old 08-11-2016, 07:44 PM
kenworth85 kenworth85 is offline
Grouchy old man
Haven't had time to do anything to with them. Just glad to hear them run good. I found another engine off a trybilt wood chipper. 8.5 Briggs will this work OK on a kart. It has a 1 inch shaft. Is there anything I need to know good or bad about it.I know very little about small engines but wanting to learn
  #22
Old 08-11-2016, 07:56 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Originally Posted by bob58o View Post
I tried to learn the product line of Tec engines. I was confused there are H50, HS50, OHH50, and a million others. I gave up!
Try following a Briggs Model type and code!
---------- Post added at 06:56 PM ---------- Previous post was at 06:52 PM ----------
The thing about the 8HP and the 1" Shaft is a 1" Clutch is very Expensive. Other than that just more Power.
Why don't you, go back to your double wide and fry something!
The Following User Says Thank You to chancer For This Useful Post:
kenworth85 (08-11-2016)
  #23
Old 08-11-2016, 08:08 PM
Grouchy old man
I had heard from someone on here that the engine off chipper had a torque problem or something I can't remember.
  #24
Old 08-12-2016, 04:42 AM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
I had heard from someone on here that the engine off chipper had a torque problem...
Only possible difference will be that a chipper engine will usually have a lighter flywheel than what would otherwise be found on a "standard" engine.
https://www.youtube.com/watch?v=c4jch0puM1A
The Following User Says Thank You to Russ2251 For This Useful Post:
kenworth85 (08-12-2016)
  #25
Old 08-12-2016, 05:28 AM
DeathMachine's Avatar
DeathMachine DeathMachine is offline
I have used the lighter aluminum flywheel from a vertical shaft engine to get faster throttle response on modified engines, works fairly well as a cheap mod.
The Following User Says Thank You to DeathMachine For This Useful Post:
  #26
Old 08-12-2016, 06:09 AM
Grouchy old man
ok that's what it was just couldn't REMEMBER. I guess that happens the older you get. would you advice me to put a heavy flywheel on it to give it a better balance(I guess).
  #27
Old 08-12-2016, 06:59 AM
Poboy kartman Poboy kartman is offline
Banned
It's a possibility. Chippers have a lot of mass on the other end of the crank. It's liable to be a little fickle on the tune and possibly jerk your arm while trying to start...but without trying it first it's hard to say. It also depends on whether the chipper was solid or belt driven and had a neutral.
The Following User Says Thank You to Poboy kartman For This Useful Post:
  #28
Old 08-12-2016, 11:49 AM
Here's what it's like starting a 5hp motor with a milled head and aluminum flywheel.
Pull faster.
It's honestly not all that bad, but if you have a wimpy pull it won't fire.
Wish I had video. I should dig through the stash and see if I have parts to build another. I know I have a tired 5hp Tecumseh laying around somewhere.
  #29
Old 08-12-2016, 12:03 PM
Russ2251's Avatar
Balance is not the issue. Inertia is the correct terminology.
It takes less horsepower to spin-up a light flywheel.
  #30
Old 08-12-2016, 05:10 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
So I guess on certain Direct Drive Chippers this lighter flywheel allows the revs to come back up faster after getting bogged by a large branch or a VERY leafy green cutting.
Whereas with a stock heavy flywheel they would stall too much.
  #31
Old 08-12-2016, 05:24 PM
Russ2251's Avatar
I don't think so.
The rotating mass in the machinery could be lightened to achieve the same end.
Also, it is probable that the lighter flywheel may be less expensive to produce.
Less chance of stalling a heavy flywheel, again because of inertia.
The Following 2 Users Say Thank You to Russ2251 For This Useful Post:
chancer (08-12-2016), kenworth85 (08-12-2016)
  #32
Old 08-12-2016, 05:28 PM
Grouchy old man
it is direct right of of the crank it starts fine 1st pull but has a lot of vibration is that common on a briggs
  #33
Old 08-12-2016, 05:31 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Thanks Russ... That does make more sense.
I thought we were Talking about a Tecumseh.
  #34
Old 08-12-2016, 05:36 PM
Grouchy old man
sorry kinda got off the subject
The Following User Says Thank You to kenworth85 For This Useful Post:
