Old 08-07-2016, 04:19 PM
Conley41 Conley41 is offline
Default Clutch issues
I recently bought a go cart with a kt100 engine and a dry clutch and when I Rev up to take off the clutch never engages. I've tried adjusting the screws with the springs but still nothing. Any help is appreciated
Old 08-07-2016, 04:33 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
Manufacturer and model of clutch?
https://www.youtube.com/watch?v=c4jch0puM1A
Old 08-07-2016, 04:58 PM
mckutzy mckutzy is online now
Pics...
Old 08-07-2016, 06:42 PM
Kelly Wood's Avatar
Kelly Wood Kelly Wood is offline
The Mad Kartist
Is the Key there?
Kelly "Mad Kartist" Wood - http://www.diygokarts.com/vb/album.php?u=9686
Old 08-08-2016, 09:37 AM
I bought it used so I don't know the make or model of it but I can put pictures up later
Old 08-08-2016, 02:51 PM
Russ2251's Avatar
Sometimes manufacturer will stamp its name and/or model number somewhere on the clutch.
Old 08-08-2016, 04:06 PM
Originally Posted by mckutzy View Post
Pics...
Here ya go
Old 08-08-2016, 05:26 PM
itsid's Avatar
itsid itsid is offline
that looks horstman to me...
Horstman HDC-5b to be precise...
Check if the clutch is at all turning over properly (as Kelly suggested.. check the key if in doubt)
Maybe it just needs some proper cleaning and maintenance (weights stuck)
or the discs are worn down and need to be replaced...
a maintenance manual is on horstmanclutches.com
(now linked)
Old 08-08-2016, 06:40 PM
Kelly Wood's Avatar
The Mad Kartist
Yup, Horstman HDC5B. Looks worn to me, I raced KT's for a bit.
Try this: Take the 5 spring compressors, and losen them at equal turns. The tighter the springs, the higher rpm is required to engage the clutch.
Basically, make it simple for the clutch to engage. If it engages more with looser springs, then your discs need replacing or you're on the right trail here.
Old 08-09-2016, 08:51 AM
Thank you guys so much I appreciate your help!
