Old 08-06-2016, 05:56 PM
wernerjerry07@gmail.com wernerjerry07@gmail.com is offline
Default Ninja
Hi does anyone know or have instructions on installing a ninja engine on a hammerhead cart? I'm very new at this, I have access to the engine but don't k ow were to begin.
Anyone have thoughts on were I may find some details?
Thanks
Old 08-06-2016, 06:06 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
Got a link to specs of said engine?
https://www.youtube.com/watch?v=c4jch0puM1A
Old 08-06-2016, 06:17 PM
No it is sitting in a box I believe it's a ninja 250but not 100%
Old 08-06-2016, 06:27 PM
Russ2251's Avatar
Would it be a Kawasaki power plant?
mckutzy mckutzy is online now
Ok... What about the kart... Got pics of that...
Aswell, where abouts are you located...
Poboy kartman (08-06-2016)
Old 08-06-2016, 07:08 PM
Its a Kawasaki, I want to put it on a hammerhead gts go cart
Old 08-06-2016, 07:22 PM
Russ2251's Avatar
Will require some serious high end fabricating skills.
Someone else will chime in.
The Following User Says Thank You to Russ2251 For This Useful Post:
Old 08-06-2016, 08:10 PM
Can we see the kart in question....
Old 08-06-2016, 08:21 PM
Russ2251's Avatar
http://www.hammerheadoffroad.com/product/gts-150/
Old 08-06-2016, 09:00 PM
Bwdeaton Bwdeaton is offline
I've done a few swaps with ninja 250 motors. Do you have all the parts necessary to run the engine? Carbs, pipes, mufflers, wire harness, cdi, fuse block, dash, radiator?
You need to mount the engine the same way it way in the bike, meaning that you have to fab all 3 engine mounts in your frame or you could use the frame of the bike and chop it up so you just have the engine cradle to mount to the frame.
Once motor is mounted you have to hook up all of the wiring securely and add a radiator, air filter, build mounts for the exhaust. Then you will need to add a clutch pedal or lever and a shifter lever and linkage to the kart.
There is a lot involved in a swap like this, but it is doable without a machine shop or tools more expensive than a welder.
All of my work till a few weeks ago was done with a 230v lincoln tombstone welder, until I got a lincoln mig welder recently. You will need a angle grinder, welder, and a variety of hand tools and clamps.
Hope this post was informative. Post pictures of the engine and I can probably ID it for you. Also if you tell us your location, maybe a local member could help you out.
The Following User Says Thank You to Bwdeaton For This Useful Post:
big-d (07-24-2017)
  #11
Old 08-06-2016, 09:18 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Sounds easy enough!
Why don't you, go back to your double wide and fry something!
  #12
Old 08-06-2016, 09:23 PM
Originally Posted by chancer View Post
Sounds easy enough!
I won't say that its easy, but it really depends on your level of experience to define how hard it will be. I've done the same swap twice, and still wouldn't say I'm too comfortable with it; however, my second swap went much better than the first.
  #13
Old 08-06-2016, 09:34 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Sounds easy enough!
Sorry
I forgot this.
What I meant was probably not the project for a guy that self proclaimed:
"I'm very new at this, but don't know were to begin."
The Following User Says Thank You to chancer For This Useful Post:
Hellion (08-06-2016)
  #14
Old 08-06-2016, 09:46 PM
Yeah this will be a hard task for someone who doesn't even know where to start. I'm wondering if the kart runs as is, because the hammerhead is already a pretty decent buggy IMO.
  #15
Old 08-06-2016, 09:54 PM
OzFab's Avatar
OzFab OzFab is offline
My #1 suggestion is pick a different user name; using your email address is just asking for trouble...
  #16
Old 08-06-2016, 10:20 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
Shhhh. I was gonna SPAM him later.
and Wait... you can d NEVERMIND
