Closed Thread
Old 01-26-2018, 10:37 AM
sailor95 sailor95 is offline
Junior Member
Default No spark fix?
Ive been doing some searching found this on EBAY https://www.ebay.com/i/282556043519?chn=ps , i am wondering if this is a solution for those in a no spark situation like myself with a quantum carbide 150cc, i also plan to replace stator along with this. Am i correct saying that this will rewire the ignition too? Any suggestions/Ideas would be greatly appreciated
Old 01-26-2018, 11:09 AM
mckutzy mckutzy is online now
What's the motor?? Pics??
Old 01-26-2018, 12:03 PM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Quote:
should be something like a 150cc GY6
https://www.ebay.com/i/161902468796?chn=ps
There are two types of people. Those who can extrapolate from incomplete data
Old 01-26-2018, 12:38 PM
Junior Member
It's for a dc fired gy6 150cc asw quantum carbide
Old 01-26-2018, 12:41 PM
Junior Member
Pics
Old 01-26-2018, 01:23 PM
Karttekk Karttekk is offline
Start with getting two new stop switches or bypass them by connecting the green and blue striped wires together. One goes in the dash next to the key and the other goes in the power box cover at the engine. I don't see the rear power box cover though. Stop switches are kill switches. Refer to the wiring diagram in this manual: http://americanlandmaster.com/pdfs/L...al-14589R4.pdf
The other components you may need are the CDI module, the magneto and the coil. Manco/American Sportworks uses a DC module. The module would be the next thing to replace once the stop switch issue is resolved and you still have no spark.The magneto is behind the gold flywheel the cooling fan is bolted to. There is a special left hand thread puller needed to remove the flywheel. The coil has two wires on the base of it and the other end goes to the spark plug. Here is the parts breakdown: http://americanlandmaster.com/pdfs/g...1/7151_IPL.pdf
You'll at least need to eliminate the stop switches or replace them to check for spark. Keep us posted with your results. Reliable Go Karts should have everything you need.
Thanks, good luck.
  #7
Old 01-26-2018, 01:34 PM
Junior Member
So your saying I connect these two together like this up by the ignition? I have a green and blue going into the two top holes of my cdi also. I have currently replaced cdi and ignition coil. My original question was more along the lines of if someone were to buy that setup I have in my op then would that be a total rewire and fix
  #8
Old 01-26-2018, 01:38 PM
Junior Member
Rear powerbox cover has been gone for a long time lol along with airbox
  #9
Old 01-26-2018, 05:22 PM
Those and the two that are supposed to go into the rear stop switch. No need to do a complete rewire I don't think. If the stop switches aren't working the spark is killed. Don't worry about the two at the CDI, look for two similar wires in the area of the power box cover. That eliminates the switches and you should get spark. Look at the schematic I sent earlier, you'll see the stop switch wiring there. They're opposite. Green on C on the rear one and green on NO on the front one.
  #10
Old 01-26-2018, 05:36 PM
Maybe there is only one stop switch on the Carbide, the Manco Helix has two. Email or call American Landmaster to verify.
http://americanlandmaster.com/WebSto...roducts_id=586
http://americanlandmaster.com/WebSto...&keyword=15271
---------- Post added at 07:36 PM ---------- Previous post was at 07:34 PM ----------
It should start with the switch or switches installed correctly and the magneto working correctly.
  #11
Old 01-27-2018, 03:33 PM
Junior Member
I remember it having one up front and one in back on the power box cover
  #12
Old 01-27-2018, 08:25 PM
Then you'll need to find those wires and put a wire nut on those too. Everything that is supposed to be there has to be there for it to run. The wires for the rear stop switch are the same colors, just installed on the switches differently. I think I understand your main question though, you're wondering if you install that complete kit you posted will your kart be completely rewired. For the most part I would guess but I would do the basics for now just to get it running.
  #13
Old 01-28-2018, 05:59 PM
leesiel's Avatar
leesiel leesiel is offline
Yardcart 196
If you have a multimeter check the voltage coming out of your pickup. I've had to replace 2 pickups on a gy6 motor only a year old.
May not be your issue but can't hurt to check your voltages. https://www.buggydepot.com/tech-cent...uide-no-spark/ this helped me out alot.
The adventures of yardcart on YouTube. Check it out.
The Following User Says Thank You to leesiel For This Useful Post:
Nosandwich (01-28-2018)
  #14
Old 01-29-2018, 06:21 AM
After looking at the pictures of the kart, you may want to think about how involved you want to get with it. I see there is no carburetor, the brake caliper is laying on the kart floor, engine covers missing (unless they are in the kart somewhere), no battery. Hopefully you can get it going again but it may end up more trouble than it's worth. Don't mean to discourage you, just trying to save you some frustration. How did you determine there's no spark by the way?
Thanks
  #15
Old 01-29-2018, 09:11 AM
Junior Member
No worries, I have all of that taken off, brakes are bad and carb is off so when I get spark all I need to do is soak and clean real well. I think my master cylinder is bad so I haven't had brakes in a while, just floor it and turn when I want to stop. We determined no spark from the usual test of trying to see the spark on the plug and also using a test light to be certain. Right now my main worry is getting it to crank and spin the tires. Will do more work on i5 when I get home from class and will get more pics up of wiring and meter readings if I can find one
  #16
Old 01-29-2018, 09:54 AM
So you're saying it used to run? "I haven't had brakes in a while, just floor it and turn when I want to stop." If it used to run, why is the front stop switch missing? Look at the steps in Leesile's post, very first thing suggested is check the stop or kill switches. I'm jumping out of this one. Hopefully everything works out for you.
  #17
Old 01-29-2018, 10:13 AM
Junior Member
Yeah it did, I lost the key for a while and tried to straight wire it but I wasn't able to and forgot how I originally had it wired
  #18
Old 01-29-2018, 10:31 AM
These forums are here to help people with their issues. In order to save time and get help, it's a good idea to tell the whole story so we can try to get you pointed in the right direction. Starting from the beginning would have saved a lot of time and effort. Saying you had no spark without letting us know exactly what you did to that point would have helped diagnose the problem. Something to consider next time you run into a problem.
Thanks
The Following User Says Thank You to Karttekk For This Useful Post:
Nosandwich (02-05-2018)
  #19
Old 02-05-2018, 03:18 PM
Junior Member
Ok so I have a black with res strip wire coming from my stator that goes into a fuse, where is this supposed to be connected to
  #20
Old 02-06-2018, 08:18 AM
I only see one fuse in the schematic that goes in the power box on top of the engine compartment. The fuse connector goes between the voltage regulator and the starter relay. Should be a red wire, not black from what I'm seeing.
Thanks
Closed Thread
