Old 04-25-2019, 04:22 PM
flowerdave flowerdave is offline
Default gas pedal
this is the gas pedal, on my kart, will that work ok using the spring of the throttle on the engine or does this pedal need a spring also
thanks Dave
Old 04-25-2019, 04:37 PM
anickode's Avatar
anickode anickode is offline
They ALL need a spring.
"Well that would be a bomb."
The Following 4 Users Say Thank You to anickode For This Useful Post:
Denny (04-26-2019), flowerdave (04-25-2019), Flyinhillbilly (04-26-2019), Panhead5496 (04-25-2019)
bthompson224's Avatar
bthompson224 bthompson224 is offline
Mine does.
The Following User Says Thank You to bthompson224 For This Useful Post:
Old 04-25-2019, 06:52 PM
mckutzy mckutzy is offline
On my bikes, the throttle is a lever, it has a spring and the motors have an additional spring added for positive return......
NO one wants a runaway vehicle...
flowerdave (04-26-2019)
Old 04-25-2019, 08:05 PM
anickode's Avatar
I actually like a fairly heavy spring on the gas pedal. Makes it easier to feather the throttle on bumpy ground IMO. A floppy pedal is just all over the place when you (and your foot) are bouncing up and down.
The Following 2 Users Say Thank You to anickode For This Useful Post:
flowerdave (04-26-2019), Panhead5496 (04-25-2019)
Old 04-25-2019, 09:59 PM
Ebrownie's Avatar
Ebrownie Ebrownie is offline
I had a pretty weak one on my kart for a bit, it returned the pedal just fine but it didnít feel good. I put a real heavy one on, now it feels way more solid on your foot and is very consistent and predictable.
The Following User Says Thank You to Ebrownie For This Useful Post:
Old 04-26-2019, 04:25 AM
thanks to all, does anyone have any close up pics so can get an idea how to attach the spring
Dave
Old 04-26-2019, 05:27 AM
This has some pretty good pics. https://kartfab.com/go-kart-plans/go...y-instructions
Old 04-26-2019, 07:55 AM
jandj's Avatar
jandj jandj is offline
That’s a Manco/Fox type pedal.
Drill a small hole in the frame for one end of the spring and hook the other end to one of the holes in the pedal.
Doesn’t get any easier than that.
The Following User Says Thank You to jandj For This Useful Post:
Old 04-26-2019, 07:58 AM
Originally Posted by jandj View Post
Thatís a Manco/Fox type pedal.
Doesnít get any easier than that.
thanks that will work well
  #11
Old 04-26-2019, 11:25 AM
I actually don't have a pedal return spring on my kart, instead there's a governor arm return spring, and a little return spring on the remote throttle mechanism.
---------- Post added at 12:25 PM ---------- Previous post was at 12:24 PM ----------
But I will probably eventually add a pedal return spring.
Currently Flathead-Crazed
  #12
Old 04-26-2019, 11:29 AM
It looks like there is room on the bar toward the front to loop the correct spring over it. I regular spring will be come back near where your foot rests.
  #13
Old 04-26-2019, 11:52 AM
When I first ran the motor without a return spring on the motor throttle lever it had worked for a bit... but eventually it had a delay upon return.. it had also dismounted the throttle hand lever once or twice aswell... after that I use a spring on the motor, never a return failure...
  #14
Old 04-26-2019, 04:46 PM
Flyinhillbilly's Avatar
The great cornholio
Always use a return spring on the pedal. There is a lot of mass and inertia there and I can tell you from experience that runaways are no fun.
The Following User Says Thank You to Flyinhillbilly For This Useful Post:
  #15
Old 04-26-2019, 07:06 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
It's also a good idea to put a kill switch on your steering wheel. So if you do get a runaway, at least you can kill the engine before you run into something.
The Following User Says Thank You to Whitetrashrocker For This Useful Post:
mckutzy (04-26-2019)
