Reply
Old 03-27-2020, 05:35 AM
Nat360 Nat360 is offline
Junior Member
Default Engine Mount
Hi. I am almost finished building my go kart, with only the engine, clutch, brakes, and throttle to go. I was looking for an engine mount for my go kart, but could only find ones that were above 100 Australian dollars. Firstly, why are engine mount so expensive? Secondly, is it possible to make an engine mount, if so, how?
Old 03-27-2020, 05:46 AM
itsid's Avatar
itsid itsid is offline
who cut the one that was welded onto your Kazuma Drifter?
Old 03-27-2020, 06:32 AM
Junior Member
It did not come with an engine mount, unless this is the engine mount (photo attached below). I thought it was a plate that is welded onto this piece, that has screw holes.
Old 03-27-2020, 07:32 AM
itsid's Avatar
well that wasn't uploading any photo...
aanyways...
this is the rear end of a kazuma Drifter:
and that is what the engine mount looks like:
just looking at this thread would've answered that
Old 03-27-2020, 07:17 PM
Junior Member
When I had bought the go kart it did not have a plate where the engine mounts to. Also, the image that you had attached, was the engine mount just a metal plate, or did it have rubber in between to prevent vibration? Below is the image of my go-kart:
Reply
