Reply
Old 03-19-2020, 02:37 PM
Liberty_Jesus Liberty_Jesus is offline
Default 5hp briggs flathead intake manifold and carb
so my raptor 3 needs a new carb as the original just wont work as its beat to crap with the throttle linkage broke and no idea if it works right. basically i need a carburetor that fits on my engine it should be a slide carburetor for ease of setting up the throttle. but i haven't found much online as to anything i can afford for a intake manifold and i have no real idea for a carburetor. any help is appreciated!
Flatheads just sound the best.
Old 03-19-2020, 03:48 PM
Flyinhillbilly's Avatar
Flyinhillbilly Flyinhillbilly is offline
The great cornholio
I made my own with a big washer and a plumbing fitting
You can't drink all day if you don't start in the morning
Old 03-19-2020, 03:49 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Look up "mikuni vm22" or "mikuni 22mm" on Ebay. The are a bunch of listings for genuine Mikunis for about $20, and 22mm is almost exactly the port size of a Briggs.
As far as intakes, the few on the web are about $50, so I feel ya there, I'm looking to Mikuni my Briggs too. Once I get a welder, I'm going to whip up a custom intake for my kart, I'll probably make a whole batch and make a bunch of money on it!
Currently Flathead-Crazed
Old 03-19-2020, 05:11 PM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
I made one... lost the carb but it think i got the intake still
I gotta fix my flathead collection
Old 03-19-2020, 05:15 PM
Won't be too easy for me to make one as my welder is a pile of junk good for stick welding practice but it's stuck at 50a from the factory
Old 03-19-2020, 05:31 PM
Aka a kenbar
If you want mine i can mail you it just the carb will need to be coupled instead of bolted or a washer welded to it on the otherside
  #7
Old 03-19-2020, 05:43 PM
Thanks for the offer but I'm going to try and make my own first. If it comes down to it maybe but for now I'll have to try and make my own. out of what I've got itll be a week or two till I can even try to make one but hopefully I can. I'm thinking a really thick plate for the flange tapping it and screwing in a pipe instead of welding it.
  #8
Old 03-19-2020, 05:52 PM
Aka a kenbar
Ok have fun with that lol now i got 100$ to biy a bunch of junk with lol
  #9
Old 03-19-2020, 09:15 PM
Austin_Gore's Avatar
Austin_Gore Austin_Gore is offline
I have a racing carb that will fit your engine with the throttle setup that you want comes with tank and it just got cleaned and everything
  #10
Old 03-20-2020, 02:38 PM
I'm still gonna work on my own but I may get back to you. Thanks for the offer though!
  #11
Old 03-20-2020, 03:18 PM
no problem
  #12
Old 03-21-2020, 10:44 AM
anickode's Avatar
anickode anickode is offline
A lot of people will make an adapter with 2 1" washers and a bit of 3/4" steel pipe. I made one for my OHV Briggs so I could run a GX200 carb on it.
Changing the length will change how your engine runs. Longer = more bottom end torque, Shorter = more top end power.
"Well that would be a bomb."
  #13
Old 03-21-2020, 11:50 AM
Alright I'll see if my little stick welder is up to the task plus I suck at welding but once I get a chance I'll try
Reply
