Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 05-24-2009, 02:28 AM
bigfootrules31 bigfootrules31 is offline
Default The dodgy whippy scooter
so i was wandering around the shed this sarvo being bored, and decided to try put a whipper snipper engine on my old kiddie scooter. i originaly wanted chain drive and found a sprocket to fit on the motor but am to stindgy to buy one for the wheel.
i had an old spindle i made a while ago laying around, so its going to be spindle driven. just gotta turn it out and tap a new thread tomorrow at school.
do you think i will need to use a turn buckle or some sort of spring to push the engine and spindle onto the wheel or should i weld it up solid,its the one with the solid tyres so theres bound to be alot of wear.
heres some picktures
ALL OF THE THINGS I BUILD ARE SO GOOD THAT THEY TURN HEADS!!!!!..........THE OTHER WAY
Old 05-24-2009, 02:59 AM
pic
Old 05-24-2009, 07:33 AM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
is that spindle....wood? it also looks a bit offcenter haha, i'd go with really strong springs or turnbuckles myself.
Old 05-24-2009, 10:39 AM
EagleTalons's Avatar
EagleTalons EagleTalons is offline
Master JB Welder
I think it has duct tape on it too!
Old 05-24-2009, 03:32 PM
nah its metal, i have to turn it out at school today, it was just sitting on the shaft.
Old 05-24-2009, 08:39 PM
SpyGuy's Avatar
SpyGuy SpyGuy is offline
Hooligan
Actually, I think it's a short club ...... to beat the **** outta y'all for giving him a hard time.
Speaking of hard times, though, might be interesting seeing if that carburetor will work sideways like that.......
The Rat: 47cc NF Cag/Daytona. Altoids can air cleaner. DuPont spraycan muffler. Brass knuckle fender. Wrench chain guard. Ask me about it if you want to know more ...
  #7
Old 05-24-2009, 08:44 PM
Pro Junk Collector
2 stroke diaphragm carb, will work in any position.
  #8
Old 05-25-2009, 02:29 AM
i got the engine mounted, and so it pivots. i need some way of mounting up a turn buckle so i can pull the engine down and up. other than that its finished.
and the carby works on its side, i had it running for a while and it didnt splutter or anything.
cant wait to see if it will moove me
  #9
Old 05-26-2009, 01:59 AM
SpyGuy's Avatar
Hooligan
Quote:
Righto, keep forgetting about those things .........
  #10
Old 05-26-2009, 02:24 AM
got it mostly finished for a test drive, pushes me along perty fast. no brakes no clutch and no kill switch.... just how i like it. now it dosent want to run, even when i put it back to horizontal, it runs for a bit then stops, those carbys must cost
-20cents to make
  #11
Old 05-27-2009, 03:25 PM
well it wasnt the carby...well kinda. theres a tiny mesh screen fuel filter inside the carby that was blocked, so now i goes good. i took it for some hi speed performance runs down the road and its pretty fast. ill put some more pics up the sarvo, if anyone else has an old whipper snipper motor lying around, i sugggest they build one
  #12
Old 05-27-2009, 03:31 PM
THE HUNTER's Avatar
THE HUNTER THE HUNTER is offline
"Ghetto Rigging Expert"
this may be a stupid question, but what is a "whipper snipper"?
it looks like it might be a line-trimmer engine?
"When you have little cash, you have to do without some things.... Like the 's' in 'Scrap Kart'...." -Me
  #13
Old 05-27-2009, 05:00 PM
Pro Junk Collector
Weed wacker.
  #14
Old 05-27-2009, 06:02 PM
Scorch3 Scorch3 is offline
Garden Gremlin?
01011110 00100000 01100101 01110000 01101001 01100011 00100000 01110000 01101111 01110011 01110100 00100000 01011110
  #15
Old 05-27-2009, 06:58 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
You will need a turnbuckle of some sort. The small ones are $0.99 at any hardware store.
  #16
Old 05-27-2009, 08:32 PM
THE HUNTER's Avatar
Weed wacker.
actually, that looks more like a Weed Eater. lol
"Weed Eater" is a registered name that Poulan uses, and "Weed Wacker" is one Sears uses.
the proper term for the tool is a line-trimmer.
sorry, im kinda a perfectionist who is into lawn&garden equipment, so i notice those kinda things. lol
but i get what you meant, thanks for confirming that it was a line-trimmer engine
  #17
Old 05-28-2009, 01:21 AM
SpyGuy's Avatar
Hooligan
Jeez, now we got a lawn-and-garden nerd .......*beats the bejeezus outta Hunter with his hundred and forty-seven different lawn and garden catalogs*
  #18
Old 05-28-2009, 01:50 AM
"The small ones are $0.99 at any hardware store."
thats WAY!!! to much, i welded a nut to the swing arm thing then a bolt goes through it and into the chassis then i just tighten it up.
  #19
Old 05-28-2009, 01:11 PM
THE HUNTER's Avatar
what would i need any lawn and garden catalogs for? im too broke to buy anything! i mostly just keep my stuff running forever and/or get stuff for free and fix it!! lol
but i might try to make a scooter like that, i gotta make at least ONE motorized toy this summer!
  #20
Old 05-28-2009, 04:34 PM
$0.99 is too much money for your budget?
Closed Thread
