Closed Thread
Old 11-06-2017, 04:40 PM
4EyedTurd 4EyedTurd is offline
Default Help identifying converter setup
I bought a used go kart and managed 4 good rides out of it before the chain started walking off. At first I tightened up the nut and then noticed Iím missing atleast a snap ring that holds the shaft on the other end. Iím trying to figure out what parts flew off when the snap ring let go. Hereís a few pictures.
Old 11-06-2017, 05:10 PM
Randy H Randy H is offline
https://www.gokartsupply.com/identify.htm
https://youtu.be/GvfkpWxxHuA
http://bmikarts.com/PDF/Comet_30series.pdf
Old 11-06-2017, 05:23 PM
What about the jackshaft setup?
Old 11-06-2017, 05:36 PM
Do you know what kind of kart this is, model?
Jackshaft looks like it's missing a bearing.
Old 11-06-2017, 06:25 PM
Baja Trax 65 but I believe it’s not a factory setup. I think you’re right it’s missing a bearing and a snap ring. A quick measure with a mic shows 1.37” OD .625 ID.
Old 11-06-2017, 06:50 PM
karl karl is offline
Looks like you need a 5/8 x 1 3/8 sealed high speed bearing , I would replace both. Buy a 5/8 snap ring and make sure the nut on the other side is not very tight, pushing on the snap ring. Easy. I would also replace the nylon nut as that holds it on the shaft, and they wear out.
The Following User Says Thank You to karl For This Useful Post:
Randy H (11-06-2017)
  #7
Old 11-06-2017, 07:00 PM
It looks like the driven clutch has sustained some damage. The spring doesn't look right either. It's probably a good idea to clean, lube and thoroughly inspect both drive and driven. All parts are available, it might be cheaper to buy new.
Maybe more pics.
Closed Thread
