Old 04-08-2020, 04:55 AM
Bakiras Bakiras is offline
Default wet clutch for 6.5hp off road gokart?
I am building an 6.5hp off road gokart which is meant mostly for hill climbing. Sooner or later i will upgrade the engine with the classsic stuff (cold air intake, jet, header etc). The tires will be 16inches tall and the net weight of this whole thing will be around 100kg without the passengers(it will be two seater). My main problem is that i dont have access to a torque converter made for gokarts because i live in europe and i cannot order something from ebay easily. My question is if i can use a wet clutch with a total gear ratio of 8:1 for the purpose i want.
---------- Post added at 04:55 AM ---------- Previous post was at 04:51 AM ----------
also i was thinking about using a scooter variator as a cvt
Old 04-08-2020, 11:47 PM
landuse's Avatar
landuse landuse is offline
Welcome to the forum. Yes, you can definitely use a wet clutch. They are pretty indestructible. Just make sure the clutch is full of oil
Bakiras (04-09-2020)
Old 05-26-2020, 12:04 PM
Der Hosser Der Hosser is offline
I bought a set up similar to that online - basically a honda gx200 clone. However, it was shipped with the clutch burnt up. Any one have any idea where I can get the wet clutch assembly? Id prefer to have the whole unit, rather than just the plate kit, since I'm not sure the clutch weight portion will fit other plates...
Old 05-26-2020, 02:34 PM
Brianator's Avatar
Brianator Brianator is offline
Gettin' er done!
You'd be better off starting your own thread than reviving an old one fyi.
"Black is the fastest color"
Old 05-26-2020, 11:05 PM
landuse's Avatar
You might have to approach honda directly. I cant think of any places that sell knock offs. They are awesome clutches though!
Old 05-31-2020, 10:45 PM
Thanks for the responses, guys. Brianator, I thought about starting a new thread, but didnt want to muddy up the site too much. Saw this thread and gave it a shot.
I ordered a honda clutch that should get here next week sometime, so I'll make sure to convey what the verdict is as far as fitting or not. Should I just continue on this thread since I started here? Or start a new one?
