Old 03-19-2020, 07:45 PM
Walter Keller Walter Keller is offline
Default 3.5 hp Briggs Parts search
Looking for a parts source for a 3.5 hp briggs horizontal shaft engine
Family YBSXS.1481HH 274459
Its a flathead ....thought it would be simple to find parts for
Old 03-20-2020, 07:47 AM
I'm not familiar with that code format......
Where'd you find those?
Currently Flathead-Crazed
Old 03-20-2020, 08:23 AM
karl karl is offline
That is the family number, not the model number
You need the model number
Old 03-20-2020, 07:48 PM
Default Briggs number
On the side of the recoil starter
Old 03-20-2020, 07:50 PM
Where should one look for the model number on the engine? Thanks
Old 03-21-2020, 07:33 AM
Yeah, that's not the right number. On older Briggs at least, the numbers are STAMPED into the metal above that area, but IDK with the 90s Briggs. Check all over for other numbers.
Walter Keller (03-21-2020)
Old 03-21-2020, 06:46 PM
Default Model number found
Found the correct model # to order parts by - parts ordered
Old 03-21-2020, 07:13 PM
Ok then! Good job!
