Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
  #41
Old 05-23-2009, 04:52 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Quote:
Originally Posted by Rotore View Post
since i have no use for this one i have now it's missing a bushing and a sleeve i hit the gear with a hammer (since i was bored and not a scratch
The gears are not the weekness of the peerless gearbox's, its the bushings and thin cast aluminum cases that break the most.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
  #42
Old 05-23-2009, 05:00 PM
Rotore Rotore is offline
Teh SPIK
Quote:
yeah ive been reading about htat on heymow. But IDK it depends on what i find a the junkyard tomorrow since i couldnt go today...
BTW On the off chance that i find a horizontal engine... and i'll be using a live axle. what would be a better combo 15T-40T or 10T-60T? (looking for some torque since i cant afford a torque converter at this time)
  #43
Old 05-23-2009, 05:43 PM
EagleTalons's Avatar
EagleTalons EagleTalons is offline
Master JB Welder
10T 60T is most torque.
The Following User Says Thank You to EagleTalons For This Useful Post:
Rotore (05-23-2009)
  #44
Old 05-23-2009, 06:14 PM
Teh SPIK
thanks eagle. i wonder if i could rund that setup with the gearbox/transmission?
  #45
Old 05-23-2009, 07:40 PM
Pro Junk Collector
If you ran a 6:1 ratio (10 to 60 tooth) after the gearbox 7:1 that would be a 42:1 ratio, definitely not what you want unless your making a rock crawler.
  #46
Old 05-23-2009, 08:15 PM
Master JB Welder
Just put some really big tires on it. :p
  #47
Old 05-23-2009, 08:21 PM
Pro Junk Collector
100" tires and you could go a whopping 25mph!
  #48
Old 05-23-2009, 08:56 PM
Teh SPIK
ok then what kind of ratio would i be lookin for?
  #49
Old 05-23-2009, 08:58 PM
Pro Junk Collector
Depends on tire size, engine size and what you want for a top speed. Check out the speed calc here, play with different numbers and find what you like.
http://www.diygokarts.com/speed-calculator.html
To get you gear ratio divide your axle sprocket by engine sprocket (example, 60t on axle 10t on engine=6:1) Same with pulleys, say you have a 3" pulley on the engine and 6" on the transmission you get a 2:1 ratio. If you have more than one reduction, such as 2:1 from engine to transmission, then 7:1 in transmission, then another 6:1 from transmission to tires you simply multiply 2x7x6=84
and since 1x1x1 is 1 then its 84:1.
(i feel like a math teacher...)
  #50
Old 05-23-2009, 09:11 PM
Teh SPIK
I've been playing with it and it keeps coming up with some car numbers.
most recent 64mph lol
put imma esperiment with a 4"pulley on the engine, a 2" pulley on the gearbox and go from there.
Closed Thread
