Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Fun
  #501
Old 09-11-2012, 10:45 PM
newrider3's Avatar
newrider3 newrider3 is online now
They're more than likely rubbing on the radius arms when turning full lock, not the fenders.
Don't let your keyboard write checks that your a$$ can't cash.
  #502
Old 09-12-2012, 01:17 AM
Orange Krate's Avatar
Orange Krate Orange Krate is offline
I just got this home yesterday. It used to be mine. I did a little to it then sold it to a coworker. He did a little then had to sell it. I wanted to at least be able to drive it before it was gone so I bought it back. Hoping to sell at a profit after having a little fun first.
Threw on a set of free, 15" used tires just to be able to drive it. Those are hard to find...that's why they're so tiny...it's all I could find.
  #503
Old 09-12-2012, 08:05 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
that body looks in great shape! nice truck. what year, motor?
as for the rubbing i havent checked where it is yet. i heard from the ford truck forum i need to get aftermarket camber bushings for any lift, even a 3 inch spacer. (i have ttb axle)
since ill be using the truck for carrying things also, i think a 2 inch block under the rear leaf spring should be good enough. the back is much higher than the front
people are telling me to just get a full 4" lift kit, but those are over $1,000 as opposed to a 3 inch spacer that's under $100.
and as for body lifts, it would be a LOT of work. id have to raise the bumpers, change the radiator mounts, modify the 4x4 shifter linkage, extend the steering shaft, unmount the cab and bed and put spacers under them, and my shifter would be lower in the floor
The Following User Says Thank You to Bluethunder3320 For This Useful Post:
Orange Krate (09-13-2012)
  #504
Old 09-12-2012, 08:12 PM
cumminsbayou4x4's Avatar
cumminsbayou4x4 cumminsbayou4x4 is offline
couldnt you but f250 springs on it
  #505
Old 09-12-2012, 08:26 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Thats why i said more offset.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
  #506
Old 09-12-2012, 08:40 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
Orange, I love the way that old boy looks. That is one cool old Ranger.
Visit www.GoKartsofTexas.com. Family owned and operated in Houston, Texas for 38 years.
Free Advice, Affordable Parts, Superior Service!
The Following User Says Thank You to Blazkowiez For This Useful Post:
  #507
Old 09-13-2012, 01:06 AM
Thanks guys! 1970 F100 completely rebuilt 360 and C4. Won't shift to 3rd and the steerings loose. I'm working on that today when I get off. One of my many projects. It's only the go-kart garage that has the one project enter - one project leave rule. LOL
  #508
Old 09-13-2012, 09:14 PM
mrfreyguy's Avatar
mrfreyguy mrfreyguy is offline
Buggy Almost Done
Originally Posted by Bluethunder3320 View Post
you might laugh at me... but i am seriously considering putting a TURBO in this truck. lots of room now!
saw a forum where a guy did it... he had 230HP and 451 ft/lbs 15lbs boost. stock is.... 145?hp and 260 lb ft
not sure how complicated it is to set one up. or the cost either...
EDIT: looks like it would be pretty complicated, id need a computer... and route the exhaust into the turbo/?
You cant pump 15lbs into a stock engine without building it up to handle that much boost. A safe range for an origionally Naturally Aspirated engine is about 5-7 psi, once you go higher you have to lower compression, re tune, run premium fuel, and address other things like your fuel pump, larger injectors, cooling, etc. Leave the motor stock and just drive it till it dies.
A wise man once told me "Your mind gives up way before your body"
  #509
Old 09-13-2012, 09:29 PM
yeah i dont know what i was thinking lol. its not simple as i first thought, ive seen someone with a turbo they slapped on a scooter, i guess its more complicated in a car.
  #510
Old 09-17-2012, 03:27 AM
Pardon me while I hijack this thread...does anyone know what this is hanging from under the column of my '70 f100?
  #511
Old 09-17-2012, 04:28 AM
fowler's Avatar
fowler fowler is offline
Steer lock
Tilt up
Tilt out
Can u not follow the mechanism
Buggy building Fast, reliable, cheap
Pick two
  #512
Old 09-17-2012, 08:09 PM
fowler might be right about the steering/tilt thing. or maybe even parking brake or something to do with the lights or wipers?
emergency flashers?
mine doesnt have steering wheel adjustments. and thats an 89. if it was steering tilt, i wonder why they wouldnt have it 20 years later? technology should be going forward. but thats not always true (if it was a bad design they may have just got rid of it)
  #513
Old 09-17-2012, 08:14 PM
newrider3's Avatar
It was optional as far back as '78 I believe, it just wasn't frequently purchased.
  #514
Old 09-17-2012, 08:22 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
I have no idea on what it is, but for some reason i seem to think maybe an adjustable brake pedal. that little uprose picture seems to remind me of the one on my adjustable brake pedal button
Great, now rebuild the engine.
Be a leader not a follower, but if your going to be a follower, follow the right leader
  #515
Old 09-17-2012, 08:26 PM
post it on the ford truck enthusiasts forum. i dont mind this on my thread. but the people at FTE should be able to tell you what it is.
  #516
Old 09-17-2012, 11:25 PM
fowler's Avatar
It's not for a load base bias valve
Adjust it when u load the truck up
Pick two
  #517
Old 09-18-2012, 03:05 AM
I did and they were kind of ****s to me and I'm not even a new member there. But it was my fault...aparently linking to pics hosted here are nor viewable to them there
Anyway, a buddy and Ford NUT at work figured it out. It's the neutral safety switch. Goes on TOP of the column where I couldn't see where it went....Carry on
  #518
Old 09-18-2012, 05:12 PM
whats a neutral safety switch??
  #519
Old 09-18-2012, 05:16 PM
devino246's Avatar
devino246 devino246 is online now
Official DIYGK Chem Nerd
It prevents the engine from being started while the trans is in gear. I would think your truck would have one. I know the older manual trannies didn't have them
ASE Certification (Engine Repair, Brakes, Electrical, Engine Performance), pending
  #520
Old 09-18-2012, 05:25 PM
crazzywolfie crazzywolfie is offline
last time i checked a neutral safety switch was only used on a automatic transmission. the only switch that i know a standard transmission has is a back-up light switch.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
